Buy M10x1.25 eye bolts?
Old Sep 9, 2019 | 02:06 PM
Franknbeans's Avatar
Franknbeans
Default Buy M10x1.25 eye bolts?
Hey all. I'm looking for M10x1.25 eye bolts to secure racing harness to the stock rear seat bolt location.
I searched and seen that bolts are M10x1.25 in size. For some reason I can not find these eye bolts anywhere.
Anyone have a clue? Or do i have the wrong size for the bolt to begin with?
Old Sep 10, 2019 | 10:44 AM
Young Wonder's Avatar
Young Wonder
I got mine from here:
https://www.ogracing.com/eye-bolt-fo...ess-mounting-2
Amazon has them too. Search G-Force eye bolt.
Old Sep 10, 2019 | 11:47 AM
Franknbeans
Looks like the link is for a 7/16th thread.
I'll look on Amazon again. I didn't see any m10x1.25
Old Sep 10, 2019 | 11:57 AM
travlee's Avatar
travlee
Master
Everything I have found is 1.5
Old Sep 10, 2019 | 11:59 AM
Young Wonder
That's what I used to mount my harness to the bottom seat belt location. It screwed in with no problem and it is holding tight. The thread size confused me too but it worked.
Old Sep 10, 2019 | 01:10 PM
Franknbeans
Hmm. are you using the location where the rails bolt into the floor?
And yup, everything I've been fining is 1.5 also.
Franknbeans
Question: I may be able to get some custom made but I will have to order a minimum of 100.
Is there a good enough market to sell these if I ordered 100?
Old Sep 10, 2019 | 01:58 PM
Young Wonder
I am so sorry I've been having a hard time reading today. I thought you wrote "seat belt location" but you said "seat bolt location". You can forget what I said. I'm not sure if there's a difference for the seat belt location and the seat bolt.
Old Sep 10, 2019 | 07:51 PM
mr. sparco's Avatar
mr. sparco
Oops wrong bolts. Edit.
Old Sep 11, 2019 | 05:50 AM
Franknbeans
Ok, i'm connecting with a company that can make custom eye bolts. Will let everyone know how it goes.
Old Sep 11, 2019 | 09:30 AM
guitman32's Avatar
guitman32
I happen to have spares of both OEM bolts and the G-force 7/16 eye bolts. The OEM bolt has a measured thread OD of .430"...measured on the G-force eye bolts is 0.417." The G-force eye-bolts thread into the OEM hole and tigthen up fine, but there is definitely more play prior to tightening vs the OEM seat belt bolts.
Old Sep 11, 2019 | 09:52 AM
iideadeyeii's Avatar
iideadeyeii
Why not just weld rings on the bolts that goes there?
Old Sep 11, 2019 | 11:08 AM
Franknbeans
no welder
Old Sep 11, 2019 | 11:21 AM
travlee's Avatar
travlee
Master
there is some guy on here, cant remember his name, that was building a custom turbo and he was doing all his own welding and they were gorgeous. if i can remember or find who it was, you could shoot him a pm to see if he would be willing to do it if you shipped him some bolts
Old Sep 11, 2019 | 03:57 PM
Franknbeans
So you're telling me these should screw right in?
https://smile.amazon.com/Williams-EB...s%2C183&sr=8-2
Old Sep 11, 2019 | 06:51 PM
guitman32's Avatar
guitman32
The ones i have are the actual Gforce ones, and they do fit. But per my measurements it seems that the OEM bolts are a slightly tighter fit. To put it in metric terms the oem bolts have a 0.33mm bigger overall thread diameter as I measure them.
Old Sep 12, 2019 | 03:25 AM
Young Wonder
It's cheap enough to buy 1 and try it out. If it works then get the rest. I think everyone is in agreement that the size is a little smaller but it holds tight.
robsilver350
Dec 30, 2013 02:48 PM
Langor
Jan 31, 2010 03:51 PM
Barrymcockiner
Oct 17, 2006 04:25 PM
