Looking for pinout on steering wheel side of clock spring
Old May 3, 2021 | 06:44 PM
Randallflagg's Avatar
Randallflagg
Default Looking for pinout on steering wheel side of clock spring
Does anyone have the pinout for a 2007 with the cruise control and audio connections from the steering wheel side? Found some info on other years but not these color wires as shown in this post:
https://my350z.com/forum/body-interi...l#post10931424
Digging through the FSM but haven't found what I am looking for yet.
Old May 3, 2021 | 07:29 PM
DarkZ03's Avatar
DarkZ03
All 10"of wires? What are you trying to do or find out, that's the better question...
Old May 3, 2021 | 07:53 PM
Randallflagg
I need to grab a ground, that's it. I assumed someone would have a pinout of that connector, even thought I saw one here but it was a dead picture, impossible to see.
I attempted to check resistance from a ground point to the pins on the connector but oddly enough quite a few of them had continuity, so I just want to be sure.
Old May 4, 2021 | 01:47 PM
Randallflagg
Ok, so if it helps anyone I found that using a screw on the steering wheel was a poor ground, it would flake out at random times. Tore the wheel apart again and did more testing. I can confirm that the black wire with silver dots, or second from the bottom is the only ground in the steering wheel. Now to post a picture...
Old May 5, 2021 | 02:20 AM
DarkZ03's Avatar
DarkZ03
I'm using my steering wheel as ground just fine, albeit just for the illumination.
curing101
Nov 1, 2017 02:41 PM
shadowm891
Mar 2, 2013 03:02 PM
jsmalnar
Oct 8, 2009 09:37 PM
Gizmo0803
Mar 11, 2008 07:14 PM
jasonintoronto
Sep 23, 2002 08:30 AM
