Roadster top repair
Old Jun 11, 2021 | 03:24 PM
Fourtalltrees's Avatar
Fourtalltrees
Default Roadster top repair
Heated rear seam of convertible top separating. I tried silicone and glue to no avail. Any suggestions?
Thanks
Old Jun 12, 2021 | 07:48 AM
jhc's Avatar
jhc
General & Tech Moderator
Thanks
You might try sewing it with #40 black fishing line and a needle, it worked on mine until I changed the top.
Old Jun 12, 2021 | 07:52 AM
Fourtalltrees
Thanks for the note. How did you ensure that the top did not leak after the sewing job?
Old Jun 12, 2021 | 08:07 AM
jhc's Avatar
jhc
Good question.
My tears were along the rear sides on the original vinyl over canvas top, not the glass area. The sewing was a PITA but it worked. Unfortunately the top was 8 years old, and after a few cycles I thought the repair had failed. Turns out the canvas had become very fragile and new tears adjacent to sewing appeared.
I think your damage may be in a less stressed area. For waterproofing you could sew and then coat with black RTV on the inside for better appearance. A pic would help. Gl!
Old Jun 12, 2021 | 08:19 AM
Fourtalltrees
I thought about combining thread and silicone. I use the car as a daily driver with the top going up and down regularly hence the separation is spreading. Here are some pics.
Old Jun 12, 2021 | 08:42 AM
jhc's Avatar
jhc
Gotcha.
Clearly the adhesive has started to fail. Once a top starts to fail sewing and patching are really Band-Aid attempts to prevent further decay. I've seen everything from duct tape to silcone "repairs." IIRC the fishing line was from Bass Pro, black nylon braided 40# test, it did exactly what I needed before other tears appeared.
If it were mine, I'd sew it at least 2" past the problem area and hope for the best. You can get a nice replacement from Topsonline.com, Hartz Stayfast canvas (not vinyl) for my 06 was $650 delivered in 2013. Changing the top at home is very doable if you have the time. (8-10 hours). Gl!
Old Jun 12, 2021 | 11:16 AM
Fourtalltrees
Thanks for the advice and the referral. I think that is what I will do.
G-Man.uas
350Z Roadster
May 2, 2010 08:06 PM
ZRoadsterClub
350Z Roadster
38
May 30, 2005 01:03 PM
john f
350Z Roadster
Jul 9, 2003 12:56 PM
adrie_79
350Z Roadster
Jun 28, 2003 07:18 AM
