DEPO Halogen-> HID retrofit, lights turn off
Old Jul 31, 2022 | 11:44 PM
stonemonkey's Avatar
stonemonkey
Default DEPO Halogen-> HID retrofit, lights turn off
Hi all,
I am retrofitting DEPO aftermarket HID headlights to a car that has Halogens. I have the 6 pin to 8 pin connector conversion worked out (I think).
Everything works, but my problem is that the HID bulbs turn off after about 30 seconds. If I turn the lights off and then on again, they come back on, but again go off after 30 seconds.
They don't both go off at the same time - the right side goes off first then the left side about 5-10 seconds later.
Has anyone else done the halogen -> hid retrofit and had this problem ?
Old Aug 1, 2022 | 12:50 PM
iideadeyeii's Avatar
iideadeyeii
Are the ballasts still getting power when they are off. Bad luck on two bad ballasts?
Old Aug 2, 2022 | 12:12 AM
stonemonkey
Thanks for the suggestion I'll check if power drops out when they turn off - is there a general issue with the stock halogen power feed not keeping up with the higher demands of the HID system ? I have seen a few threads on 350 HID retrofit to a car that had halogens and I haven't seen anyone mention the need for an extra relay/power feed to run them.
Old Aug 2, 2022 | 05:05 AM
iideadeyeii
No, I have this swap and no issues
Old Aug 2, 2022 | 08:15 AM
Heel Til I Die's Avatar
Heel Til I Die
Generally speaking, if the lights are going out randomly after being illuminated, then that's a sign of a bad HID ballast, or possibly in your case, ballasts.
Since your Z didn't come with OEM ballasts, where did you source them? Are they OEM or new from a reputable manufacturer? Same questions with regard to the HID bulbs.
Old Nov 13, 2022 | 10:42 PM
stonemonkey
Just closing this one out for future reference - you (and others) were on the money with the ballasts. The ones I had were aftermarket Amazon units. I sourced some used OEM Nissan ballasts and hey presto, all working.
Thanks everyone for your help.
djwatts
Oct 31, 2008 07:25 AM
Jun
West Canada
20
Mar 20, 2006 04:59 PM
MemphisZ
Jul 15, 2004 06:01 AM
silverz
Mar 4, 2003 12:36 PM
