Rust in trunk
Old Feb 6, 2025 | 05:35 PM
mcubed45's Avatar
mcubed45
Default Rust in trunk
Hi guys,
I found this random spot of rust in my trunk area under the strut bar while I had my interior out (installing reverse camera). Any idea where this would be coming from? Is there any areas that are prone to leaking that would cause water to accumulate there? This spot is covered by the plastic liner and carpet.
Thanks!
Old Apr 4, 2025 | 08:40 AM
amsoik's Avatar
amsoik
Normally I would say replace the metal. But in this case, the damage not being any worse, and being you absolutely killed the rust. I say GOOD REPAIR! Keep up the good work.
Tutuapp 9Apps
Old Apr 4, 2025 | 11:26 AM
icer5160's Avatar
icer5160
I don't think that rust spot was caused by a leak in the rear hatch. It's no where near the wiper arm assembly, latch, or outer seal.
I suspect that's old, probably from some kind of liquid spilling in the trunk. I would treat the area, remove the rust and paint over it to prevent it from growing further.
Cheers!
-Icer
blinkme323
Dec 29, 2008 07:46 AM
evolved326
Jun 4, 2008 09:54 PM
Mike Wazowski
Southern California
15
Dec 28, 2006 08:49 PM
WellsA
Feb 12, 2003 06:17 PM
