2008 convertible wiring diagram-storage lid issue
I’ve been trouble shooting my storage lid issue for several years now following the RF trouble shooting sequence(lid locks do not unlock).
I have what appears to be a grounding issue with the orange wire in the harness connector B66 coming into the soft top control unit terminal #15. I’m trying to trace this wire as the diagnoses appears a harness issue. If I disconnect the LH lock connector the ground continuity issue goes away. I’ve replaced the storage lid LH lock and that’s not the grounding issue. I’ve also replaced the plate rail switches so that’s not the answer.
The 5th bow opens all the way but the next sequence which is the unlocking of the storage lid doesn’t occur.
does anyone have a complete wiring diagram so I can trace down this alleged harness issue and re run a wire? Thank you.
