Gauges
Old Apr 14, 2004 | 06:57 PM
IsatteliteI's Avatar
IsatteliteI
Lightbulb Gauges
I have a couple of questions about gauges.
Are there any companies that make gauges that match the look of the factory gauges (little ones in the middle)?
I have an idea about a gauge pod on the (A Pillar?) that's a little different from what I'm seen so far and I want to try it out. If it turns out that it actually works, what kind of gauges is everyone putting in there? I mean I don't have Turbos or anything fancy like that so what could I possibly put in there? I'm don't really care what they do, as long as they're doing something and look like the factory ones. Thank you for any advice.
Old Apr 14, 2004 | 08:14 PM
pwrshftd350z's Avatar
pwrshftd350z
id like to know that too, which ones should we put in, 48 mm, 52 mm? i think 52 mm, not sure though. also, should we put oil pressure, oil temp, water temp? any ideas would be appreciated
Old Apr 15, 2004 | 12:12 PM
IsatteliteI
Default is it possible
This may sound a little crazy, and it may be too expensive for someone to even bother considering but I'm just brainstorming here...
The multifunction digital gauge on top of the dash, is it possible to have two connected to whatever the original one is connected to, and perform two different functions at the same time? If it turns out this is possible how much would it cost? Thanks for any info.
--Still looking for factory looking gauges-- If I have any luck I'll let you guys know.
Old Apr 15, 2004 | 01:00 PM
cslithergo's Avatar
cslithergo
I would check out motorcycle HD catalogs. They run a lot of Digital gaues with small mounts. I know I have seen a few that would work on the pillar.
Old Apr 18, 2004 | 06:44 PM
Tobey's Avatar
Tobey
i had defi dseries in my wrx. they have orange backlighting with red pointers. i believe they have them with white or black faces but in 52mm (2") only.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
