Adjusting the Window height???
Old Apr 19, 2004 | 10:41 AM
joutwate's Avatar
joutwate
Default Adjusting the Window height???
Sorry if this is a duplicate, the forum search seems to be down.
On the passenger side of my car, the window seems to be set too high. So when the auto-up button is pressed for the window it gets to the top and then immediately retracts down 5 inches. The dealer told me there is a reset button inside the door panel to reset the max window height. Unfortunately, acutally very fortunately, I had a new stereo installed and dyna-mat was added. For them to access this "magic button" they need to remove the dyna-mat.
My question is, does someone have instructions on how to reset the max window height so I may do this myself. Also, is there a picture out there of where the button is on the door panel so I might be able to just exacto out a hole for it rather than remove my dyna-mat.
Any help is much appreciated.
Old Apr 19, 2004 | 09:49 PM
fresno350's Avatar
fresno350
you might try to open your passenger door, unhook the battery. then hook back up the battery then close it, or close it then hook up the battery, i forget. it reset my windows one time that way. i would try that before you go cutting.
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
