plastic covering on paint?
Old May 21, 2004 | 05:15 PM
fresno350's Avatar
fresno350
Question plastic covering on paint?
back in front of the rear wheel well, down on the bottom, i noticed some plastic tape like material starting to tear and come off. is it ok to peel it off and what is it? has anyone seen this yet? its on that small panel in front of the rear wheels. thanks
Old May 25, 2004 | 05:15 PM
fresno350's Avatar
fresno350
no one has seen this?
Old May 26, 2004 | 04:20 AM
lovetoclown's Avatar
lovetoclown
I have the clear car bra and it also covers the rear splash gaurds.
Old May 26, 2004 | 08:29 AM
silverstoneTT's Avatar
silverstoneTT
Someone take it off and tell me what happens because mine has a little peeling all along the length of it and it looks bad. I dont want to take it off though because Im scared that it would look worse. I know my friends Neon has something just like it.
Old May 26, 2004 | 12:38 PM
swong13's Avatar
swong13
That is a paint protectant film similar to the 3M clear bra. It is on the front edge of the rear wheel well since that area sticks out a little bit and is susceptable to stone chips from stuff coming off of the front wheels. Probably not needed if you have splash guards. My neighbor has the same thing at the same place on his G35. My roadster also has this on the tonneau cover where the convertible tops sits when it is in the up position.
If it is peeling off you might want to replace it. Anyplace that installs the clear bras should be able to put a new piece on. Wonder if that is a part that is available from Nissan. I plan to have a professional installer do the clear bra on my car but that little piece should be a do-it-yourself job.
-Steven
Old May 26, 2004 | 12:57 PM
yobri's Avatar
yobri
If you haven't yet located a clear bra specialist, I suggest going with Jeremy at Invisigard in Santa Rosa. He's done a lot of Bay Area board member's Z's... if you want to PM him for more info, his user name here is krinkov
ablaine
Nov 29, 2016 10:13 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Cashwin
Oct 1, 2015 06:36 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
