I need some spacers!!!!! any good spacers 25mm+ besides H&R?
Old May 24, 2004 | 12:31 PM
Daewoo's Avatar
Daewoo
Default I need some spacers!!!!! any good spacers 25mm+ besides H&R?
I need some 20-25mm (or larger) Spacers that are decent but I cannot find H&Rs (or anything comparable) in stock. Any ideas?
Thanks
Old May 24, 2004 | 01:14 PM
aaaaa's Avatar
aaaaa
are you running on 18 or 17? 18 you sould get 25mm rear and 15 mm for front...
i never saw sapcers larger than 25mm for 350z..
i need to get the info too...
BUMP~
Old May 24, 2004 | 03:36 PM
swifty949's Avatar
swifty949
try crow? I dont know if they ahve a website, but they are located i think in Torrance CA. Just call 411. I think it's crow wheels or crow racing or something... :?
Old May 25, 2004 | 07:27 AM
Daewoo's Avatar
Daewoo
thanks. I only need them for the rear. Never thought it would be this tough.
Old May 25, 2004 | 07:56 AM
350zluvr's Avatar
350zluvr
I've been curious about spacers too. If/when you find where to get them please post here. thx.
Old May 26, 2004 | 06:56 AM
Daewoo's Avatar
Daewoo
will do.
Old May 28, 2004 | 07:50 AM
old_s13's Avatar
old_s13
fred goeske owns wheelspacers.com and custom machines spacers and wheel adapters to whatever specs you need. he is a serious businessman who will make whatever you desire, as LONG AS YOU KNOW THE SPECS. his prices are very fair considering he sells top notch stuff. i've been running his spacers for a long time and have had ZERO problems, although.. I wish I could say the same about the days when I used to run cheap spacers.
if you're going to do it, do it right.
Old Jun 1, 2004 | 02:08 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you want to stay with a hub-centric spacer...
i wouldnt go over 20mm personally... i do not like the DRM spacers... i prefer DRS...
DRM Bolt up to the stock hub bolts and then have new bolts sticking out of them for the wheels to bolt too... those are 25mm and up...
DRS replace the hub bolts with longer hub bolts and slip on between the wheel and the rotor... they are avaialble in 5, 15, 20mm kits... they include longer hub bolts...
http://www.performancenissanparts.co...roducts_id=385
Old Jun 1, 2004 | 12:38 PM
LaPuLaPu's Avatar
LaPuLaPu
Anyone know the pro’s and con’s of adding a spacer? TIA
Old Jun 2, 2004 | 03:48 AM
Daewoo's Avatar
Daewoo
I found fred goeske on line and have already spoken with him. He will make me a set of billet aluminum 35mm spacers in a matter of days. cost $190 shipped COD.
When I spoke with him he seemed like a hell of a nice old guy. I am doing a little more research and likely take the plundge in a week or so.
Question - If I put the wheel on (with no tire) and there is about 2 inches of space btwn the wheel and the outer wheel well. How much will the tire stick out from the wheel? I am going with 305s or 295. I am guessing about 1/2 inch so I am going to get 35 mm spacers.
Thoughts?
Old Jun 2, 2004 | 07:22 AM
blackZon19x10's Avatar
blackZon19x10
25mm spacers are huge and are not really recommended to get the job done. Call MC MOTOR SPORT in CALI. Tell them you need hubcentric spacers..the number is 909-947-5115..speak to Steve. Tell him you know Jason @ Donz Wheelz
Old Jun 3, 2004 | 11:17 PM
Jason@Performance
Performance Nissan
you may need these then too...
infact you need them
http://www.performancenissanparts.co...roducts_id=161
