Intense Motorsports LIP - How to install??
Old Jun 22, 2004 | 07:15 PM
Jetpilot718's Avatar
Jetpilot718
Default Intense Motorsports LIP - How to install??
Hey all, just wondering how you guys installed this lip: http://intensepower.com/rsabsfrlip35.html
Im having it sprayed tomorrow, and I did not see any mounting hardware/double sided tape in the box. Does this thing come with hardware??
Any input is appreciated!
-Steve (doesn't like surprises)
Old Jun 23, 2004 | 01:51 AM
SQUILL's Avatar
SQUILL
Default Re: Intense Motorsports LIP - How to install??
Hello i believe that is phoenixZ33's car in that picture on intenses site you should send him a pm and ask him , he will more than likely know!
Old Jun 23, 2004 | 03:01 AM
havabooz's Avatar
havabooz
ask the shop thats painting it to fit it and drill holes...tape might be enough but tape+bolts is recommended
Old Jun 23, 2004 | 03:03 AM
Cain96's Avatar
Cain96
That looks like a Nismo Replica. You should be able to use all the OEM clips that is if all the holes line up.
Old Jun 23, 2004 | 11:55 AM
Jetpilot718
Thats just it, there are no holes. This is all I have to work with:
Old Jun 23, 2004 | 11:57 AM
Jetpilot718
another angle
Old Jun 23, 2004 | 11:58 AM
Jetpilot718
another
Old Jun 23, 2004 | 11:59 AM
Jetpilot718
lastly..
So what do you guys make of this? What should I use? Double sided tape and self tappers on the inside wheel well pieces?
Old Jun 23, 2004 | 01:06 PM
erock's Avatar
erock
Post pix when you get it installed.
Also can you do me a favor, can you measure the clearance you have before and after the install? I'm debating on whether I should lower my car or not because my driveway is hard enough to drive onto. Lip looks pretty good.
Old Jun 23, 2004 | 01:57 PM
Jetpilot718
Will do, I planned on doing this anyways to see if there will be much of a difference in height with/without it.
Old Jun 24, 2004 | 12:26 PM
Jetpilot718
BUMP
Come on guys, I need to know what sh*t to buy to install this thing. Where can I get the hardware?? Doublesided tape??
Old Jun 24, 2004 | 12:35 PM
synth19's Avatar
synth19
This is what you should do:
Attach the lip starting with the middle section and move it around until you have a perfect alignment (get a friend to help you, it will be hard to do this yourself).
After the lip is placed and centered, have your friend hold the lip in place, then take your hand and feel for two bolts (2 on each side of the bumper-at the ends/corners of the lip).
Mark where the bolts line up to the lip.
Take the 4 bolts out and drill a whole where you marked on the lip.
Put double sided tape on the middle portion.
Put the lip back on and insert the bolts onto the lip.
DONE.
Old Jun 24, 2004 | 12:40 PM
synth19's Avatar
synth19
^ btw, these instructions are pending that the lip reaches the bolts under the car.
Old Jun 25, 2004 | 11:47 AM
phoenixZ33's Avatar
phoenixZ33
Old Jun 25, 2004 | 11:50 AM
phoenixZ33's Avatar
phoenixZ33
You can get hardware at well, the hardware store. Get black screws too, not cheesy silver shiny ones that will stock out and look dumb.
Old Jun 25, 2004 | 11:57 AM
phoenixZ33's Avatar
phoenixZ33
The spoiler should have come with two brackets for the bottom.. you sure the body shop didn't lose them when they unpacked the lip? Either way they are two 4" long strips of metal with holes drilled on each side, should take about 5 minutes to make. Otherwise call Intense and say you never got them, they should mail some right out. No biggie...
Old Jun 26, 2004 | 01:12 PM
titanjc's Avatar
titanjc
Does anyone have any pictures of this lip on their car? Maybe with the stock sideskirts? Or maybe in SilverStone?
Old Jun 26, 2004 | 11:27 PM
phoenixZ33's Avatar
phoenixZ33
search around in this forum, there is anothe thread about the same lip. it's titled "where can i get a cheap urethane lip" or something, it should be 2-3 pages back, the thread is less than a month old.
Dymsi
Sep 29, 2015 11:32 AM
