Door panel removal...help?!?!
PASSENGER DOOR FINISHER
Removal
1. Remove cap inside handle portion and remove screw.
2. Insert taping flat-bladed screwdriver into edge portion, disconnect pawls, and remove door grip finisher.
3. Remove screw of door grip portion.
4. Remove finisher power window sub switch.
5. Disconnect harness connector power window sub switch.
6. Remove screw of power window sub switch portion.
7. Pull up door finisher and remove connector inside handle cable and lock **** cable.
Removal
CFAUVEL
Oct 1, 2015 03:20 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
