thermo-tec installed!
i got around to installing my thermo-tec laceable heat shield on my intake piping. this mod is probably more of a cosmetic mod than a performance oriented one but i'm sure the intake piping will stay a tad bit cooler. either way, i am happy with the results of the install. was not that bad of an install. the laces wrapped along the bottom of the intake tubing is for looks only it wasn't necessary to wrapped them. a while back i was considering acquiring an injen upper intake pipe for cosmetic reasons, then i saw this stuff. here is a link if anyone is interested
http://www.jcwsportcompact.com/autop...p-7621/c-10102
here are some pics
also, i will be installing my kinetix V4 plenum and UR pulleys just as soon as i receive my cusco strut bar from intense motorsports. i want to do it all at the same time. can't wait!!!!! also, with the next week and a half i hope to have received my 14" wilwood brake kit, varis CF air duct and some bluebatmobile overlays. my next mods are cusco sway bars, pi-thon compression fittings, and kinetix cats.
!!!!!!!!!!!!!!!!!!NEWSFLASH!!!!!!!!!!! as i was writing this the fedex dropped off my brakes unexpectedly!!!!!!!!! guess i wil be busy tommorow or sunday!!!!!!!! woohoo!!!!!!!
here are some pics
I made up the same thing using the bubble wrap that is silver coated on both sides which is used for window sun shades. It is very cheap, and I just cut it to size and secured it to my Injen intake pipe using large band clamps.
I have not taken any yet. Actually, this is the first post where I have seen someone take the time to insulate the intake track. Sure the Injen looks great out of the box, but the thin wall tubing heat soaks very quickly. I've felt it immediately after driving = hot, and after driving with the insulation = much cooler. Great mod for just a few bucks. As for looks, the material is thicker because it has an air barrier in the middle. In other words, it does not look quite as smooth as the picture at the beginning of this thread. However, in my opinion, all it takes is a little attention to attend to the looks.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
