Plug for rear wiper hole
Old Sep 13, 2004 | 09:56 AM
dannichols's Avatar
dannichols
I hear that, I've broken about 4 but didn't get around to replacing them. Instead just moved the ones I still have around enough to hold things in place. Someone could make a killing on aftermarket fasteners. I picked up some supposedly NISSAN fasteners at Lowes in their spare parts bin and they weren't even close to useable. Does anyone have any better ideas for broken fasteners, that are cheap?
Old Sep 13, 2004 | 10:03 AM
dannichols's Avatar
dannichols
To pull out the fasteners that get stuck I have had good luck using a 1.5" plastic putty knife from Lowe's that I cut a notch into (see image). I push this inbetween the fastener base and sheetmetal and simply pull up and they come out really easily. The putty knife is also great for gently lifting up the panel so I can get my fingers behind it to pull.
File Type: bmp
Old Sep 13, 2004 | 05:15 PM
BILZ Z's Avatar
BILZ Z
Default Pics of the painted nylon plug w/o grommet
Originally posted by dannichols
Bilz, is it easy to match the black paint of your Touring? I've had trouble with my silver..even work I had done at a body shop didn't quite match.
anyway, I'd like to see how the nylon plug looks painted.
Here you go. This is the nylon plug from underneath. Once inserted with a little around the top edges, I surrounded the plug/hole joint with the clear silicone.
Old Sep 13, 2004 | 05:23 PM
BILZ Z's Avatar
BILZ Z
Default Re: Pics of the painted nylon plug w/o grommet
Here's the plug before cleaning off the excess silicone
Old Sep 13, 2004 | 05:27 PM
BILZ Z's Avatar
BILZ Z
Default Re: Re: Pics of the painted nylon plug w/o grommet
A few after cleaning and waxing
BILZ Z's Avatar
BILZ Z
Default Re: Re: Re: Pics of the painted nylon plug w/o grommet
Another
Old Sep 13, 2004 | 05:32 PM
BILZ Z's Avatar
BILZ Z
Default Re: Re: Re: Re: Pics of the painted nylon plug w/o grommet
Another
Finally, an outside pic. I'm real happy with the low profile of the nylon plug w/o the grommet. I'm picking a new grommet up from Nissan, $4.00. Just to have it on hand when it comes time to reinstall when I sell the car..... not for a real long time though.
Old Sep 13, 2004 | 07:14 PM
azaz's Avatar
azaz
Default Re: Re: Re: Re: Re: Pics of the painted nylon plug w/o grommet
Nice job BILZ Z! Where did you get the plug from and do you have the part # ?
Old Sep 14, 2004 | 09:27 AM
BILZ Z's Avatar
BILZ Z
Default Re: Re: Re: Re: Re: Re: Pics of the painted nylon plug w/o grommet
Got it at Home Depot. They are in the cardboard pull drawers with all of thye other nylon plugs, fasteners, etc. in the Hardware Dept. I'll stop by the store & get the exact part no.
Old Sep 14, 2004 | 09:28 AM
BILZ Z's Avatar
BILZ Z
Got it at Home Depot. They are in the cardboard pull drawers with all of the other nylon plugs, fasteners, etc. in the Hardware Dept. I'll stop by the store & get the exact part no.
Old Feb 10, 2005 | 04:36 PM
corsair's Avatar
corsair
I picked up this metal plug at Home Depot. I believe it is similar to the Hillman Plug mentioned earlier.
Old Feb 10, 2005 | 04:37 PM
corsair's Avatar
corsair
and the actual metal plug
Old Feb 10, 2005 | 05:20 PM
350zWarz's Avatar
350zWarz
i think thats the same one i got...the rear looks alot better now with it installed
Old Feb 12, 2005 | 03:30 PM
maximumsportZ's Avatar
maximumsportZ
Default Re: Plug for rear wiper hole
After much searching found a plug at Lowes that fits the rear wiper hole perfectly:
What have you guys used to cover it up?
I want to do this tomorrow! lowes is like 2 mins from me.... Can you tell me the specific area in lowes I can find this plug???
Thanks
Old Feb 12, 2005 | 06:43 PM
Rayden2001's Avatar
Rayden2001
Yeah the car looks better without the rear wiper. I just had the hole welded shut when it was getting painted but this is a very clean fix for the same look.
Old Feb 13, 2005 | 09:37 AM
Z-INCOGNITO's Avatar
Z-INCOGNITO
Default Re: Re: Plug for rear wiper hole
Thanks
HARDWARE DEPT.
I used something different... but i forgot where i got it from...
kyin
Oct 15, 2015 05:54 AM
