Door panel removal
Old Nov 12, 2004 | 04:36 PM
JimH's Avatar
JimH
Default Door panel removal
Any shortcuts or other valuable hints when removing my drivers side door panel? I have a loose connection in the window control that makes me tap the door pretty hard to get the window to come up.
How does it come off?
Regards, Jim
Old Nov 12, 2004 | 04:51 PM
Srivero297's Avatar
Srivero297
I replied in the other door panel post about this-- check it out.
Also- just to let you know, the window thing is a common problem with the 350z. If your car is still under the 36k mile warranty, I would go to a dealership and get it fixed under warranty. I just got mine fixed at 26500 miles, no charge to me.
Old Nov 12, 2004 | 05:26 PM
Jun's Avatar
Jun
- the foamy piece comes out by pulling it from the back (the side opposite of the control piece).
- unscrew the screw that holds the control piece, then that comes out.
- you will see two bolts i believe that are inside after removing those two pieces, remove those.
- By the door handle, pull back the door handle, pull out the little plastic cover (it pops out) and you will see a screw there as well, take that out.
- Unclip the door panel from all around the sides.
- Once everything is unclipped, pull up and take it out.
Old Nov 13, 2004 | 07:52 AM
Z-Z's Avatar
Z-Z
http://liljerk.morpheus.net/350Z/front_speakers/
Old Nov 13, 2004 | 09:40 AM
Srivero297's Avatar
Srivero297
When I removed my door panels, I didnt remove the screws in the armbar and behind the door handle and they still came off. Are you sure this is necessary?
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
