Feedback & Suggestions for Our Forum This is NOT a place to ask car/modification questions!
For posting feedback, suggestions or comments regarding our My350Z.com forum.
i need help my car wont acelerate
Old Oct 24, 2017 | 07:13 AM
ofdrive's Avatar
ofdrive
Default i need help my car wont acelerate
hey guys i have a 2006 350z and one day the gas pedal just dint work animore push it all the way in and noting so i put scanner and the coda say tps low voltage so i replace the tps sensor in the pedal and dint work than i instal a new thtottle body and still dont work please i need help
Old Oct 24, 2017 | 07:21 AM
iideadeyeii's Avatar
iideadeyeii
Did you do a throttle reset procedure?
Do this and report back
Old Oct 24, 2017 | 07:33 AM
ofdrive's Avatar
ofdrive
yes i did that or a least the one i found on youtube if somebody have the instructions of how do it please
Old Oct 24, 2017 | 07:39 AM
travlee's Avatar
travlee
Master
http://forums.nicoclub.com/how-to-pe...n-t576592.html
ENGINE COLD
Perform "Accelerator Pedal Released Position Learning" .
Make sure that accelerator pedal is fully released.
Turn ignition switch “ON” and wait at least 2 seconds.
Turn ignition switch “OFF” wait at least 10 seconds.
WAIT over 10 seconds before this next step.
Perform "Throttle Valve Closed Position Learning" .
Turn ignition switch “ON”. WAIT EXACTLY ONE SECOND SHARP. Turn ignition switch “OFF”
THEN wait at least 10 seconds.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. - Very hard to hear anything at all. Just believe this is happening by faith.
Now, here's the big change
Start engine and warm it up to normal operating temperature.
AND RIDE YOUR CAR FOR AT LEAST 15 MINUTES, this will make for correct operating temperatures to happen within the engine for the following steps. Warming your car in the garage in the morning aparently does not cut it.
Turn ignition switch “OFF” and wait at least 10 seconds.
Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
Repeat the following procedure quickly five times within 5 seconds.
Fully depress the accelerator pedal. Fully release the accelerator pedal.
Wait 7 seconds
Fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turns ON.
Fully release the accelerator pedal within 3 seconds after the MIL goes off. Start engine and let it idle. THE ENGINE MUST BE STARTED WITHIN THE 3 SECONDS AFTER IT STOPS BLINKING, THATS HOW THIS LIGHT GOES OFF. THE SERVICE MANUAL DOES NOT STATE THIS, BUT IF YOU LOOK AT THE DIAGRAM WHERE THE ENGINE LINE ON-OFF IS, IT CLEARLY SHOWS YOU SHOULD TURN IT ON WITHIN THESE THREE SECONDS.
This is where your engine will start to learn the correct idle settings
Wait 20 seconds.
Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
Old Oct 24, 2017 | 07:44 AM
ofdrive's Avatar
ofdrive
ok i will fo that today and see what happend thanks a lot
