Need new fuel maps
Old Nov 24, 2004 | 01:48 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default Need new fuel maps
so...i just drove into los angeles...from new mexico
went from 5500ft altitude to sea level...my car was tuned perfectly at 9lbs putting out sae corrected #'s of 465hp 446tq
i figured if i turned the boost to 6lbs here in california, that the difference in altitude would keep similar power and a decent a/f ratio...only gonna be here for 4 days, so i wasn't too concerned with re-dynoing my car...but the car at 6lbs here on manual setting feels pretty weak, i am assuming the car is running rich, unfortunately i dont have an a/f gauge to monitor that at this time....so i'm hoping one of you can help me "mcguyver" my car so it will run smoother.
i was wondering if you think this would help/could help with my issue...if anyone on this forum has a tt at sea level (or near sea level) could you please post:
digital pic of fuel map (profec-e01)
pounds of boost
power #'s (if available)
if anyone could help me with this, that would be awesome, i'm hoping to change my fuel map, and be able to rectify the problem..if any suggestions/comments, please go on and give em!
thanks!
Old Nov 24, 2004 | 03:51 PM
7 eleven's Avatar
7 eleven
If you don't have a wide band it would be akin to suicide to try to tune the maps or even just use a set up from another car. Way to many things that could go wrong and you just would end up with a blown motor.
Just hold off, get a wideband and get it tuned right. It's the safest route and there is little gained by rushing into it.
Gary
Old Nov 24, 2004 | 04:01 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i know u are prolly very right... i may go and get it dynoed this fri ... and keep my new maps recorded. so i can switch them out if i drive out to cali again.
Old Nov 24, 2004 | 04:19 PM
westpak's Avatar
westpak
SFZCC
That sounds like the best idea, make sure you save the current MAPS on the e01 card before changing them.
Old Nov 25, 2004 | 12:36 PM
braceman's Avatar
braceman
You have mail..
Regards
Kostas
2ndchanceZ
Oct 26, 2015 08:03 PM
