Super Charger and TT
I was speaking to a fellow Z fan over the weekend, and he told me that putting in a TT into a car that didn't come with one to begin with would damage the engine. Any truth to this? He also made a comment that it would be safer to put the super charger in after driving it for a while. In regards to the Super Charger, he said that it wouldn't do as much damage to the engine, but would still effect it negatively in the long run.
With the amount of people putting in TT's into their Z's, I'm not sure if he was all to correct, but I figured I would ask anyway. Same goes for the Super Charger what's the deal with that, what if a Z has both of them ?
Thanks in advance...
It just depends on how much boost you are going to run. You can run low boost without damaging your engine. If you want to run higher boost then you will have to get forged internals. Both superchargers and twin turbos can damage your engine if not done right. And if done right, both can be reliable in the long run. But there are more parts on the supercharger that need to be replaced overtime.
I do not think that one will damage the engine more than the other. Both are forcing more air into the engine. The only difference is how they do it. But like adrianko43 said, both are fine as long as they are done right.
Awesome, just one more question though, do you mean both individually, as in one or the other? -- or both at the same time?
Or...does everything you guys said apply to one or the other and both?
WTF? English
Arin
LOL, sorry about the confusing reply earlier -
Arin, I did get that much, but what I want to know is what if I put in both a super charger AND a TT at once?
I appreciate it, thanks again all.
Arin
However it's not worth the effort on a street car. On a stock bottom end you can blow the bottom end apart with just one or the other. It's best place is mostly car shows.
Alamo did this with a MR2 and it worked well.But they invested alot more time and money into it then almost anyone who didn't own a shop would bother with.
Gary
I don't see how a supercharger would be any more reliable then a turbo. N/A engines from factory can take 5-8psi safely, as long as theres enough fuel. Stock turbo cars are already built for forced induction so they can averagely force 8-12psi. 5-8 psi into the Z is safe but installing a turbo does take life from your engine, n/a last longer; less wear and tear.
Turbo is the way to go. Many debates over turbo or supercharger; turbo always comes on top overall.
Okay, I'm a n00b, obviously, when it comes to things like this, in theory, say the money was not an issue, COULD both systems be installed on the same car, without risk to engine life?
Would I be correct in saying that a supercharger will give me the upper hand against an all wheel drive like the WRX for example, while the TT gives me the upper hand in the long run? In the end, creating a killer both from a stop and/or roll?
This stuff is pretty interesting to me and I'm damn new to it, so be easy if I ask something stupid.
Arin
Arin
Originally posted by 97supratt
Well if money wasnt involved then I would say yes it is very easy to supercharge and turbocharge a vehicle. BUT, it has been proven that one or the other is more efficient and not both. If you do some research on how the units work, you will know why its not efficient. Also, turbo's arent meant for top end, I think what your referring to is "turbo lag" which comes with the bigger sized turbo's. That is one of the advantage of superchargers (no lag), but then again it is driven by your crankshaft energy which you also add weight to the rotating mass which in turn doesnt give you a lot of power. To cut a long story short, turbo+supercharger= could be done and it has been done, but isnt efficient. I hope that helps.
Arin
Arin
My recommendation would be to ride/drive in a TT "Twin Turbo" 350z and a SC'd 350z outputting about the same power. I have done this and have driven both. I wanted a SCger at first but if I wanted to create more power it would have been more hastle and limited to where a turbo can create more power easier and almost indefinitely to what the turbo can do. I too thought of the "turbo lag". But the Z is built for lowend torque. I dynoed at 247 with basic mods. At 1800-2k my car produces 200+ ft lb torque. With that amount the Z doesn't really have a "turbo lag". I personally felt the TT was a faster car and acted stock unless you punch it. I'll stop now because this is something I too was comtiplating.
Arin
