Clutch recommendations for FI
Old Dec 15, 2004 | 05:09 AM
g356gear's Avatar
g356gear
Default Clutch recommendations for FI
Because several of the FI guys on the board have upgraded their clutches I wanted to get some feedback on the set-ups being run and their characteristics. Feedback on cost, engagement, chatter,driveability, etc. would be great. Do you love you're set-up and would you buy it again??
Old Dec 16, 2004 | 12:33 AM
orhanz33's Avatar
orhanz33
there's a groupbuy on the ATC clutch, although i don't know anything about it
check out this thread:
https://my350z.com/forum/showthread....hreadid=100141
Old Dec 16, 2004 | 01:16 AM
dansouliere's Avatar
dansouliere
Its actually the ATS carbon clutch and if you do a search you will read nothing but good things about them.
Old Dec 16, 2004 | 06:31 AM
jak's Avatar
jak
Default Re: Clutch recommendations for FI
I went with the Unorthodox Feramic 6 puck and Unorthodox flywheel. They are being installed now at CJs along with the APS kit. I will give some driving impressions after I drive it.
Jeff
Old Dec 16, 2004 | 10:01 AM
g356gear's Avatar
g356gear
Anyone with clutchmasters, ACT, Exedy, etc????
Old Dec 16, 2004 | 10:44 AM
luanda's Avatar
luanda
Went with ACT Street Racing Clutch (not six ouck) and Jun flywheel - good for approx. 450lb ft tq and feels like stock - nice smooth transition.
Old Dec 16, 2004 | 01:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Myself, 350ZDaKalb, and Enon Exec all went with the ATS twin disc carbon clutch and flywheel. It's the ulitimate clutch...in my opinion. If you look hard, you can find them for under $2000, and the win disc carbon can support 700-800hp and as stock pedal feel and stock engagement. As the discs heat up, they grip even more. Similar to the Exedy twin disc, but several hundred dollars cheaper.
And the entire clutch/flywheel assembly weighs about 26lbs. I have yet to drive a car equiped with one, but everything I have heard about them has been positive. With dual floating carbon discs, it will be the last clutch you ever buy.
Old Dec 21, 2004 | 10:58 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Default Looks like Exedy for me...
aalzuhair has an Exedy Twin-Plate Clutch and Flywheel combo and this is what he told me about it in a PM. BTW, this pretty much sold me on it.
In a PM from aalzuhair who has an Exedy clutch/flywheel:
But anyway the Exedy twin carbon clutch its very smooth on engagement it does not jerky or come on too strong.
At first, the clutch pedal felt a bit harder than the stock clutch but not hard that it would be inconvenient for a daily driven car. The car does make a bit of a noise at idle and below 2000 rpm’s (some times) but once you have the car on the go it feels like stock. In heavy traffic its not harder than the stock clutch, I have not noticed any deference in driving comfort.
But I can tell you that with fast shifting the clutch do its best and this is where the money is. When I shift fast from the start the car engages some smooth that a lot of people told me that me shifting skills have gotten much better. I have received a few complements about how fast I shift without jerking the car, and I tell them it is all in the clutch.
So yes it was worth the money. I got the clutch from Ultimate Racing, which they got it from Adam at Z1 performance. They bought it for me because I asked them to get me the best clutch system available in the market for the 350z. I would rate Exedy clutch / flywheel combo at a 9 out off 10, just because I believe that nothing is perfect.
Q: How many Exedy clutches are available?
A: I think 3 are available. One plate, twin and 3 plates all carbon. But the one I have is the "Hyper Carbon Series, Semi Carbon Multi, Twin carbon clutch / flaywheel combo" it runs for about $2800 or so and that is the one your looking at and it will be the last clutch you will ever buy
Q: how much hp and tq is the Exedy supposed to hold up to?
A: Well on Z-1 Performance it says like 750hp (Idon't know if they mean wheel HP or flaywheel HP), but according to others, it can hold much more than that, however, Exedy under rates their clutch to be on the safe side.
Old Dec 22, 2004 | 06:43 AM
SecretAgent's Avatar
SecretAgent
for the money, the ATS is impossible to beat, but i wouldn't quite call it the ultimate. that would have to be Tilton's 7.5" triple carbon/carbon. course, the tilton is nearly 2 1/2 times more expensive than the ATS.
Old Dec 22, 2004 | 08:45 AM
Sharif@Forged
Forged Performance
Well...LOL...if you want to go crazy extreme....ATS makes a triple disc carbon with heavier pressure plate. Good for 1200trq. Roughly $400 more than the twin disc...but probably overkill for just about everyone.
Old Dec 23, 2004 | 05:49 PM
Guru's Avatar
Guru
Actually the triple plate is nice for drivability. It is lightly easier to modulate than the twin plate although both are excellent.
Old Dec 27, 2004 | 11:50 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
We are having a group buy special on our tilton clutches. Street or semi-street, with the 8lbs flywheel.
These are very nice setups for the FI 350z's, they will allow the car to rev up faster, thus allowing the turbo to spool much quicker. Also, if you have a SC, then this will be a good setup as well, as you are able to get up into the power band quicker (for some SC kits).
http://www.performancenissanparts.co...th=153_175_372
Old Dec 27, 2004 | 12:22 PM
mazzoo's Avatar
mazzoo
Two of the best clutches are the ATS and the Tilton. Performance Nissan looks to have a very good price for the Tilton.
ATS:
Tilton:
Old Dec 27, 2004 | 12:25 PM
dansouliere
Is the tilton really worth the extra coin?
There seems to be allot more options on the ATS clutches. Does the tilton need to be adjusted or can you install it and forget it like the ATS?
Old Dec 27, 2004 | 12:33 PM
mazzoo's Avatar
mazzoo
As far as I know the Tilton will be fine for Driving around town and running it hard. Now if your car is a drag car and that all you do is run it down that track and really beat the hell out of the clutch then yes it will need to be adjusted from time to time.
Guys pick me up on this if I am wrong. Thanks
Old Dec 27, 2004 | 03:21 PM
G3po's Avatar
G3po
Default Tilton
What kind of crank power will the Tilton dual carbon hold?
Old Dec 27, 2004 | 07:59 PM
Sharif@Forged
Forged Performance
Holy cow.its almost $1700 more than the ATS twin disc??? With an 8lb flywheel, it will be about 8 lbs lighter than the ATS. Does anyone know how much the Tilton full assembly weights? Has anyone ever driven this? 8lbs seems awfully light for road usage, even with a full face carbon twin disc..just my opinion.
Old Dec 27, 2004 | 08:13 PM
mazzoo's Avatar
mazzoo
The Tilton weights about 14lb. I am using the Tilton clutch with my build and have it at the shop now. If anyone wants I can have the shop take pictures with both the ATS and Tilton clutches side by side. There is a BIG size differences between the two clutches. If you want I can have the owner of the shop do a write-up on both clutches like he did on the Greddy and APS turbo kits. Let me know if this would be helpful.
Old Dec 27, 2004 | 08:42 PM
Sharif@Forged
Forged Performance
Yeah, that would be great to see a side by side comparison. So you are saying that the entire assembly weights 14lbs with the clutch, flywheel, and pressure plate? everything?? That is incredibly light.
Cant wait to hear/see how it drives. There are a bunch of about to use the ATS twin disc carbon, so we can comment on that one soon.
Old Dec 28, 2004 | 03:10 AM
bascelik's Avatar
bascelik
I'd like to compare:
* noise @ idle
* revving in neutral (throttle response)
* starting from still (modulating, etc.)
* clutch engagement (high/low, how quick)
* pedal feel vs. stock
* <add here>
Heck, I'll throw my car in the comparo if desired, it has stock clutch and pedal (the only thing is, my RPMs drop faster, due to SC).
I'd really like to see such a comparo.
