FI Build Up - Daily Driver
Old Dec 20, 2004 | 02:23 PM
ReavTek's Avatar
ReavTek
Default FI Build Up - Daily Driver
Hey Guys,
I have been interested in forced induction on my Z for quite some time but have been hesitant as I am seeing many people have problems with it. What I want to know is what can I do to make my engine be able to withstand the abuse of FI? I was planning on going with a Vortech Supercharger or a Power Enterprise Turbo system and keeping it around stock boost. Here is my list of what I think I should need to be able to flog my car daily:
Forged Pistons
Forged Rods
Connecting Rod Bolts (Is NISMO sufficient?)
Titanium Valve Springs
Any suggestions?
Old Dec 20, 2004 | 02:51 PM
going deep's Avatar
going deep
Depending on your final hp and torque goals...here are a few more items to add to your shopping list:
The rods you order will probably come with ARP rod bolts
ARP Main/head studs
Fuels system upgraded, bigger injectors, fuel return sys, bigger fuel
pump Walbro 255
Main/rod bearings
Clutch and Flywheel upgrade
Gasket kit (includes heads and manifolds,....)
Depending on the system, engine management system
NGK 1 step colder spark plugs
Gauges, boost, afr, oil press, fuel press, egt
Boost controller/turbo timer...if you go TT
Ceramic coating on the pistons
Get your block blue printed/balance
Dont port/polish the heads
Some guys are going with different valve setups too, such as Ferrea valves
Oh yeah, set aside about 10k for all of the above plus labor. Not to even mention purchasing the FI system. Overall, it will be close to 15-20k depending on the FI sys you go with.
A lot of the forged internal stuff could take up to two months to actually recieve it depending upon the brand you go with.
Old Dec 20, 2004 | 03:13 PM
redline tt's Avatar
redline tt
true
Old Dec 20, 2004 | 09:55 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default Re: FI Build Up - Daily Driver
you better not keep it at stock boost if you are going through all of the effort of building the engine with forged internals!
you should be able to safely run at least 15psi if you do it right...going deep basically described what he and myself are in the middle of right now- building our motors to aim for 550rwhp uncorrected, actual numbers
Old Dec 20, 2004 | 11:14 PM
ReavTek's Avatar
ReavTek
I just want it to be safe for daily driving. I keep hearing all these horror stories about snapped rods and blown motors. If I plan I keeping around stock boost what should I beef up to make it 100% safe? Just rods and bearings maybe pistons?
Old Dec 20, 2004 | 11:24 PM
going deep's Avatar
going deep
When you start building your motor and you do a mental estimation, you tell yourself "Yeah, about 3k in parts and 3k in labor, that outta do it". But, when you start the build up, next thing you know you're knocking on 10k after adding this and that. Most of which you really need, otherwise it means trouble down the road. I really believe this will be worth it in the end, but its a hell of road trying to get there. I have been the type of guy that buys a new car every two years or so. Thats pretty wasteful. But, with this project Z car that it has now become, I will definately keep her for a long time. So, just think of all the money Im saving by not taking it in the shorts as a trade in.
Old Dec 21, 2004 | 12:58 AM
nitrous350's Avatar
nitrous350
Install APS TT Kit with basis Boost (6.5 ~7.5 psi)
and Forged 9.5 CR CP Piston I think you can Run every day
with out any problem >>>>>>>>
Old Dec 21, 2004 | 07:19 AM
speedform's Avatar
speedform
Give SPGracing a call. They have a pretty comprehensive list of what you need to build an engine. They also offer built engine packages to suit your budget. From what I can tell from the list you have above your looking at around 4g's for the engine plus your core and labour.
I wish I had the coin...
Old Dec 21, 2004 | 07:49 AM
going deep's Avatar
going deep
The weakest link on the VQ-35DE are the connecting rods and I can personally attest to that fact. You can't just replace the pistons and say its all good.
Old Dec 21, 2004 | 08:20 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
speed form meant SGP Racing* not SPG Racing, I believe.
I personally think you are going to have to be more specific, saying you want a 'daily driver' is pretty general, that's a wide range of hp and tq numbers to determine what you want.
My plan is to have a 450-550rwhp and rwtq daily driver but have the potential to boost up to 650rwhp and rwtq when need be. So an hp and tq goal you want to achieve can help us determine what could be good for you.
Below is a comparison of Pauter forged rods and stock rods...the bottom are the Pauter rods and top are the stock rods. I am pretty sure the bottom pistons are Arias. And of course, top piston is stock.
Attached Thumbnails FI Build Up - Daily Driver-pauter-rods-compared-to-stock-rods.jpg
Old Dec 21, 2004 | 08:25 AM
dansouliere's Avatar
dansouliere
Time will tell how reliable the APS TT kit is on the stock block with the stock tune. There is no reason why you would need more then 420rwhp for a daily driver. There is only so much HP that is 'streetable'
You need to come up with a HP number in order to determine what you need to spend. for 400rwhp you can get away with just buying the TT kit and a clutch ($10,000). Any more HP than that you need to double that number to do it properly.
Old Dec 21, 2004 | 05:47 PM
ReavTek's Avatar
ReavTek
I am planning 400rwhp to 450 rwhp with the possibility in the future to run it to 500rwhp. 500rwhp is my absolute limit on this car. Those pauter rods look very beefy, are there any other brands you would recommend? Also, I plan on doing an engine build for FI then breaking in the built motor without a turbo... Then install turbo after the break in period. Is that a good idea? Finally, here is what I think I will need:
Rods
Pistons
Rod Bearings
Valves and Valvesprings
MAYBE a mild cam
My theory is only the stuff doing all the movement needs beefing up for my target hp goal. What do you guys think?
Old Dec 21, 2004 | 05:51 PM
ReavTek's Avatar
ReavTek
Sorry for the double post but I had another question:
What is a good "streetable" clutch/pressure plate/flywheel assembly?
Basically, something that I can slip a little not something that is either 100% engaged or 100% disengaged.
Old Dec 21, 2004 | 09:23 PM
speedform's Avatar
speedform
[QUOTE]Originally posted by Nissan350ZTT
[B]speed form meant SGP Racing* not SPG Racing, I believe.
Yes...SGP Racing. sorry...
Old Dec 21, 2004 | 10:35 PM
Brandon@Forged
Rods
Pistons
Rod Bearings
MAYBE a mild cam
Well Pauter is great, but I plan on using Crower rods. Pistons i'm not sure about yet, i'm still considering the brands and prices. I don't believe you will be able to run the internals for the turbo while n/a, I don't think 9.0:1 or lower CR internals are going to work for N/A, so I would just break them in with the turbo. Just buy whatever you can when you can, and then have it all installed at once and save on installation costs and 350Z down time. Might want to check and see if there is a group buy when you get ready to buy your stuff.
My plan -
Pistons (still considering brands and price): XT, Arias, SGP Racing, or custom JE's.
Rods: Crower.
Cams: Tomei 264's.
Valves, valve retainers, valve springs: Custom Ferrea.
Sleeves: Darton
Radiator: Blitz
Head and Main Studs: SGP Racing/ARP
Fuel: Altered Atmosphere Return-fuel system
NGK Iridium 1-Step Colder Spark Plugs
Nismo Low-Temperature Thermostat Kit
I'll determine later what else needs to be upgraded.
Streetable Clutches - ACT street disc, Clutchmasters FX200 or 300, Exedy Hyper Carbon Twin-Plate (comes with Exedy flywheel), Nismo, O.S. Giken Dual-Disc, JWT, i'm sure there is probably others I didn't list.
Flywheel - JUN, JWT, RPS, Nismo, Stillen, Unorthodox Racing.
My plan for clutch: Exedy Hyper Carbon Twin-Plate Clutch and Flywheel, why?, it's streetable and holds a tremendous amount of power.
Anyway, hope this helps and maybe by listing what I plan on doing it can help you in your desicion making.
--Brandon
Old Dec 22, 2004 | 07:33 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
brandon...here's my list (maybe this will help you)
Arias Pistons
Pauter Rods
AAM Fuel System
ARP Main & Head Studs
NGK 1 step colder plugs
RC 550cc injectors
ATS Clutch & Flywheel
Wastegate Springs -TIAL .8bar 38mm
Overhaul Gasket Set from nissan
Oil Pump from nissan
Clutch Release Bearing
Main & Rod Bearings
Block -used (mine has a hole in it)
Old Dec 22, 2004 | 08:11 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Arias Pistons
Pauter Rods
AAM Fuel System
RC 550cc injectors
Main & Rod Bearings
Just curious, how much is the overhaul gasket set from Nissan? ...it was $530 for my old car....
Old Dec 22, 2004 | 08:58 AM
going deep's Avatar
going deep
183 at Performance Nissan
http://www.performancenissanparts.co...oducts_id=2065
Old Dec 22, 2004 | 08:59 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
$190
go to www.nissanpartsdistributor.com
Old Dec 22, 2004 | 09:00 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
the new oil pump was cause i blew my old motor..and am assuming there is garbage in the old oil pump...dont want to take any chances.
