Crank/Cam angle sensor wire fix: GB Interest list only
Old Jan 12, 2005 | 02:19 PM
  #101
350zDCalb's Avatar
350zDCalb
builtZmotors
my motor will most likely be going back in my car the week after next..will this wire be ready by then?
Old Jan 12, 2005 | 02:47 PM
  #102
POPA 350z's Avatar
POPA 350z
Sharif,
Will you PM everybody once the wires are done with all the info?
Or we have to keep and I out for updates when its done?
Old Jan 12, 2005 | 02:57 PM
  #103
phunk's Avatar
phunk
CJ Motorsports
350zDCalb: There is no chance that they will be ready by then.
The plugs will be ordered on Monday if we go thru with this, and in which case it will take about 3 weeks from then to get them ready to ship.
Old Jan 12, 2005 | 03:08 PM
  #104
luanda's Avatar
luanda
Hey Phunk,
Will you be doing the same analysis on the cam wiring?? I know you're the first to say there may be no benefit and you may not have the time.
Just curious....
Old Jan 12, 2005 | 05:21 PM
  #105
phunk's Avatar
phunk
CJ Motorsports
I have datalogged the car for 5 dyno passes.
The car is running 5psi of boost with a greddy kit on an otherwise stock car, even the exhaust.
The crank trigger signal appears to be picture perfect. Perhaps I am not scoping it right... but I mean at lower RPM my settings showed it looking very textbook, and then at higher RPM i dont get any noise at all... just the signal is a lot more brief and I dont see the same profile... but its clean.
Here is a sample from AROUND 6000 RPM... you tell me if you see any noise...
so at any rate... I am going to send a test cable to a shop that currently has a high boost running 350z at their dispense... and they are going to test it to see if it takes care of a little thing that they are suspicous of the crank trigger signal of.
Guys, I will build and sell these if you want it done... but I really wanted to prove something with them first... and so far I am not getting anywhere. If the shop that tries out the test harness doesnt see any difference or improvement of a wierd thing that is being reported... then I would only sell these as a pure novelty, such as a grounding kit... I dont like the idea of selling something i cant prove works... thats not in my nature... but if you guys want it for the JUST IN CASE factor... I will gladly claim that "this product MAY help in prevent erratic crankshaft position sensor reading interpretation by the ECU".
After the other shop tests it and checks to see if it does anything for them... well... that and my day today is all the time I really have to spare for a product like this... If i cant see some kinda results... unless there is still a demand for it as what I will call a novelty, im just gonna drop out.
-Charles
CJ Motorsports
Old Jan 12, 2005 | 05:34 PM
  #106
booger's Avatar
booger
Thanks Charles ..your an upstanding guy . Let us know what the other shop finds out .Sounds like this problem just may be a hit and miss problem . I may have you do the cam sensor wire if your going to make them . I put in new cams and Ive read some are getting bad signals from them . [what do you think ]..Bill
Old Jan 12, 2005 | 07:57 PM
  #107
luanda's Avatar
luanda
Perhaps wait a bit for the APS article - is this still on for next week?
Old Jan 12, 2005 | 08:24 PM
  #108
5thgenluder's Avatar
5thgenluder
My car was the official test car and Charles and I looked for a noticable change or erraticism in the crank trigger for a while with no results. Well maybe its more common in higher boosting cars or maybe its 1 out of 20 cars. Dont know but still wouldnt hurt as I always say. Charles thanks again for spending as much time on this as you did you and your crew really are amazing people. Thanks James
Old Jan 12, 2005 | 09:52 PM
  #109
AmyCroft's Avatar
AmyCroft
Smile Mystery Buyer
GQ_626 Wrote
48) TECHNOSQUARE
49) Z350Lover (Crank Wire) International Order
50) AmyCroft (For his mystery buyer...hehe)
Sharif - My 2 1981 280ZX Tubo Coupes have a Crank Angle Sensor
Heavy Sheilding from Factory - The Signal is flawless..
I just ordered a 60mm throttle body (a 240 SX type) to put on the 90.000 mile (white) Car
I have a thing for antiques.. HA !!
Cheers Amy -
Old Jan 12, 2005 | 10:04 PM
  #110
350zDCalb's Avatar
350zDCalb
builtZmotors
thanks for all of your work (whether it proves to help or if it ends up to be just a what-if factor)
how difficult is it to swap in this wire?...i imagine having my motor out makes it much easier, but even with it installed, when you have the wire and connector or whatever fabricated, is this a big job to swap this wire in?
thx
TODD
Old Jan 13, 2005 | 04:14 PM
  #111
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Phunk your results dont surprise me. APS only noticed the interference on some cars....and under certain high boost conditions. It was really weird...very erratic. But at the end of the day, they decided to add the shielded cable to their kit.
And even if the interference is only present in 1 out of 10 cars boost 8psi or more, I would still buy the cable.
Papa's, I will start a specific Gb thread if everyone still wants to go through with this..
Old Jan 13, 2005 | 04:23 PM
  #112
MIAPLAYA's Avatar
MIAPLAYA
I do still want to...I also would like to know what kind of diffculty there is in swapping these cables..
Old Jan 13, 2005 | 04:27 PM
  #113
phunk's Avatar
phunk
CJ Motorsports
easy swap... soldiering of a 3 wires at the ECU... and routing the cable to the sensor.
Old Jan 13, 2005 | 04:29 PM
  #114
KShep's Avatar
KShep
I'm still interested.
Old Jan 13, 2005 | 04:36 PM
  #115
MIAPLAYA's Avatar
MIAPLAYA
How hard is it to get to those sensors and also is it possible to just pin the end of the wire and then swap the entire pin out of the ecu harness?
Old Jan 13, 2005 | 04:54 PM
  #116
QuantumZ's Avatar
QuantumZ
ECU pins can be hard to come by since there are so many different varyations.
I think most ppl who have five digit investment in their cars will still do this, even if it is only on 1 of 10. Call it insurance. Most ppl won't know if they're the one until they destroy the motor.
I'm down.
Old Jan 13, 2005 | 10:59 PM
  #117
Sharif@Forged
Forged Performance
OK, group buy has officially begun.
https://my350z.com/forum/showthread....hreadid=106288
Old Jan 15, 2005 | 05:24 AM
  #118
Sharif@Forged
Forged Performance
bump...any chance of a moderator pinning this thread for a week?
Old Jan 15, 2005 | 04:21 PM
  #119
MIAPLAYA's Avatar
MIAPLAYA
I'd like to know how hard it is to swap out this wire with motor in the car?
Old Jan 15, 2005 | 04:55 PM
  #120
phunk's Avatar
phunk
CJ Motorsports
very easy... just plug it into the crank trigger and run the cable thru the firewall to the ECU.
