New rear axles...
Old Jan 4, 2005 | 09:40 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Default New rear axles...
I was told by ZXRage that I would need to change the rear axle in order to handle the goals I want. Here's a place that sells rear axles: http://web.inetba.com/dss/item158471.ctlg I believe one of these is used on the Performance Motorsports 350Z. Level 5 hold 800hp, so i'm not sure what they used. Sorry if it's a repost, but I don't believe i've ever seen anything about this before.
Old Jan 5, 2005 | 01:21 AM
mjedens's Avatar
mjedens
Default Level 2
I bought these a couple months ago after breaking 1/2 axles at the drag strip. They hold up!!
Old Jan 5, 2005 | 05:50 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What are you WHP goals?
And mjedens, how much power and what type of tires were you running when you snapped the stock axles?
Also, how is the noise and virbration on these units?
Old Jan 5, 2005 | 11:41 AM
mjedens's Avatar
mjedens
Default gq_626
500 rwhp & 550 torque. Snapped coming off the line with 8 psi on MT ET Streets. With the new 1/2 axles, same power, on full slicks, no problem. (Leaving the line @ 6500 rpm's with n2o)
No noise and no vibration noticed on highway driving.
Old Jan 5, 2005 | 12:45 PM
zimbo's Avatar
zimbo
How complicated is the install of 1/2 axles?
--KY
Old Jan 5, 2005 | 02:54 PM
Brandon@Forged
450 - 550rwhp and rwtq daily driving, and the easy ability of 650rwhp and rwtq. I'm not sure what level 3 or 4 hold, if they go by 100's, level 2 = 500, level 3 = 600, level 4 = 700, level 5 = 800, so either level 4 or level 5.
Old Jan 5, 2005 | 05:40 PM
g356gear's Avatar
g356gear
--KY
Easy...with the right tools. There are I think 6 bolts that attach each axle to the stub axles that come out of the differential. On the outer hub is a large single nut with a cotter pin. This comes off and the axle slides out to the inside toward the diff.
Old Jan 5, 2005 | 05:44 PM
g356gear's Avatar
g356gear
Default Re: gq_626
These are the outer shafts that broke??? Where abouts....in the boot or the shaft itself??
Old Jan 6, 2005 | 01:55 AM
mjedens's Avatar
mjedens
g356gear:
The shaft itself snapped.
Nissan350ZTT:
They only have a Level 2 and Level 5. IMO a 5 is only needed for a full drag car that is 1000 rwhp plus. The 5 is also two times the price and I'm not sure about streetability.
Old Jan 6, 2005 | 11:11 AM
Brandon@Forged
g356gear:
Nissan350ZTT:
Will a level 2 be sufficient for my goal?
Old Jan 6, 2005 | 02:54 PM
mjedens's Avatar
mjedens
IMO, yes!!
Old Jan 7, 2005 | 04:44 PM
uplz4588's Avatar
uplz4588
if you are a man then you would go for LV. 5!!! J/k man... it says they are good to 500hp, if you want 500whp thats a differetn story .... thattle be like 550-570 hp so LV2 may not be strong enough
Old Jan 8, 2005 | 01:57 AM
mjedens's Avatar
mjedens
I've got a great suggestion !! Nobody buy anything until you see that you have a problem. There have only been a few of us that have snapped the axles and I believe it's always been on the drag strip.
