ENGINE BUILDERS: Main and Rod bearings..what's the big deal???
Originally posted by 350zDCalb
wow...awesome info!
will the machinist be able to order the bearings w/just calling nissan? or will he need the service manual?
wow...awesome info!
Originally posted by gq_626
Yes, as long as he gives Nissan the numbers off the crank and block.
Although i would recommend that you give your machine shop a copy of the service manual that deals with engine assembly/dissassembly.
One quick question for the experienced!!!!-
What is the recommended main/crank clearance?
What is the recommended rod/crank clearance as well?
Would anybody know if the system is simpler thanthe honda B series bearing color code system?
Rod to crank clearance is .0013 - .0023 limit is .0028
The rod bearing selection table is easy....there are only 3. The main bearing is much more complicated like I noted in an earlier post.
