Another happy APS owner
Old Jan 28, 2005 | 12:49 PM
BrianLG35C's Avatar
BrianLG35C
Originally posted by calimarc
I think with GQ explanation and the points I offered the discrepancy in numbers are plausibly explained. Free flowing exhaust makes a big differance with turbo applications. Of course the room to gain power by leaning out the A / F ratio would be where I'd expect more of a differance. Remember these kit come very very rich out of the box leaving much room for power gains with experienced tuning. Last but not least differant dyno types alone can offer so many figures I'm learning. Differant dynos for differant purposes. So I can see an 80 rwhp differance with all these things considered.
Calimarc,
I understand what you're saying. I'm just trying to educate myself (from you and others) on the APS kit and its true "out of the box" potential. I realize exhaust makes a bigger difference with turbo application but didn't realize dynos could vary this much with very similar setups.
Old Jan 28, 2005 | 12:51 PM
APS's Avatar
APS
Default Re: Re: My results
Originally posted by BrianLG35C
Huh. Zippycar on 350zmotoring.com dyno'd over 440whp @ 8lbs & conservative tuning. Why such a difference?
Power difference could easily be the difference between 91 and 93 octane fuel and thorough dyno tuning, the type of dyno that GRD utilise is imho the most accurate and repeatable type of dyno for power measurement, no chance of tire slip due to the hubs being bolted directly to the dyno, tire slip makes it very difficult to acheive accurate power readings
Peter
Old Jan 28, 2005 | 12:56 PM
APS's Avatar
APS
I agree and thanks for elaborating, but 80hp?
If you take into account, fuel octane (91 v93) thorough dyno tuning and the difference between the APS test pipes, the APS cat back V the other exhaust utilised the power could be easily 80 WHP, very easily.
Peter
BrianLG35C's Avatar
BrianLG35C
Thanks Peter, I mean Turbo Peter
Old Jan 28, 2005 | 01:00 PM
APS's Avatar
APS
Originally posted by mojo powered
A dyno dynamics graph could be anywhere from 10 to 15% different from a dynojet!!! Crazy but very true.
To give you an example: An stock STI dynoes at around 210whp on a DD dyno, whereas they dyno closer to 240whp on Dynojet.
Correct, that's also been my experiecnce, the Dynojet dyno generally reads higher than a dyno dynamics dyno.
Peter
Old Jan 28, 2005 | 01:12 PM
APS's Avatar
APS
No problem at all, I can see why guys get so confused with dyno readings, it's my opinion that the only meaningful power comparison is on the same dyno type, same day, same environmental conditions, otherwise guys will get really confused.
About a year back we tested a highly modded STI on 3 different types of dynos on the one day and had power readings which varied by 50 WHP.
The best dyno test is a back to back test on the one dyno and to compare the before and after power readings, anything else is really a waste of time.
At APS we have run many dyno days for car clubs and it's amazing the WHP that some cars/engines don't have, some guys think they have up to 100 WHP more than they really have, that's why I also like to utilise speed over distance to verify the power measured by the dyno.
If you know the weight of the car and the MPH the car runs over the 1/4 mile then basic math will show you the REAL HORSEPOWER of the engine.
Peter
Old Jan 28, 2005 | 01:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Peter
What is the calculation for that?
Old Jan 28, 2005 | 01:43 PM
zero2prove's Avatar
zero2prove
Originally posted by gq_626
Becuase they likely used an inertial based dyno..such as dynapack or dyno dynamics...etc. The numbers can vary wildly based on how the dyno is setup.
That is why a dynojet is better for car to car comparisons. You are just spinning a known mass, which never changes...and there is nothing to really calibrate. Load based dynos are better for tuning, however.
The roller mass doesn't change but the surface of the roller does. I would imagine on higher HP cars with more torque this affect the readings. You would have to take this into account as well.
From all the dyno's I've seen the Dynodynamics reads the lowest.
Tuan
Old Jan 28, 2005 | 03:13 PM
hurahn's Avatar
hurahn
Default Re: Re: Re: My results
Originally posted by G3po
The APS 91 octane base map should be closer to .5bar , not .7bar
I'm fuzzy on this stuff my damn self. My gauge recorded a max reading of 0.7 but in everday driving it's 0.5-0.6. I'm sorry this picture is so bad. I'll do better when the car gets tuned. Thanks for the input.
Old Jan 28, 2005 | 03:57 PM
damen's Avatar
damen
your car seems to run off of the chart rich in the higher rpms. so with some tuning you should be able to get more power of it after all.
Old Jan 28, 2005 | 04:04 PM
calimarc's Avatar
calimarc
Calimarc,
I'm learning quite a bit myself. I'm comfortable posting some things that I feel I understand now. Everything I have learned has come from these boards and the great people that share their wisdom and passion for fast high tech cars. I have the APS kit so naturally I have an interest to have my own reliable knowlege of F.I. and my Z. When the time comes for my install I will want to trust the shop I chose. I sure as hell will want to know the the basics to protect my investment needless to say !
Old Jan 28, 2005 | 04:17 PM
APS's Avatar
APS
Good point Damen, looking at that air/fuel ratio graph the mixtures are far to rich/fat, an air/fuel ratio of around 12 to 1 at around 5000 rpm sloping down to approximately 11 to 1 at around 6600 rpm on would result in far greater power.
Peter
Old Jan 28, 2005 | 04:19 PM
hurahn's Avatar
hurahn
Oh yeah, there's more power to be had. I just wanted to make sure everything was good to go for driving around in it's current form.
Old Jan 28, 2005 | 04:28 PM
booger's Avatar
booger
Peter...... could you tell us the way you find out HP . With the Wt. of the car and trap speed ?
Old Jan 28, 2005 | 04:43 PM
dansouliere's Avatar
dansouliere
+1
Old Jan 28, 2005 | 04:45 PM
G3po's Avatar
G3po
Default rwhp calculation
Personally I have a "Tazzo G meter" that calcualates ~rwhp automatically over either a 0-60 or 1/4mile run. It's a great street tuning tool. It even can masks out shift points which disrupt the calculation.
Old Jan 28, 2005 | 04:48 PM
booger's Avatar
booger
+ 1 ???
Old Jan 28, 2005 | 05:30 PM
  #38
dansouliere
+ 1 ???
lol
+1 means I am also interested in knowing the same thing.
I usualy use the "I'm with stipid" icon that most other forums have.
Old Jan 28, 2005 | 05:36 PM
  #39
APS's Avatar
APS
I'm at home now, when I'm at work on Monday I wil post the info for you.
Peter
Old Jan 28, 2005 | 06:20 PM
  #40
basam350z's Avatar
basam350z
Here is a link to come calculators, but don't ever quote them to people, they'll just give you Sh|t.
http://www.speedworldmotorplex.com/calc.htm
The ET method
This method uses the weight of the car and the time it took that car to travel 1330 feet (¼ mile).
The formula is: hp = weight / (ET / 5.825)3
The Trap-speed method
This method uses the weight of the car and the speed at which the car completed the quarter-mile run.
The formula is: hp = weight * (speed / 234)3
