Dyno #'s at Stock Boost!
Old Feb 9, 2005 | 09:08 PM
webcarconnection's Avatar
webcarconnection
Cool Dyno #'s at Stock Boost!
Hey everyone!!!
I went to the Dyno and my #'s are good... at 5.6 PSI I put 371 RWHP and 324 RWTQ... the runs are in 4th, my A/F is 10.9 at the top end and the temp. is around 90
Here are a few pics of the car and the Dyno Sheet!
Enjoy!
http://www.imagestation.com/album/pi...31280917&idx=0
Old Feb 9, 2005 | 09:47 PM
going deep's Avatar
going deep
Very nice numbers for stock boost.
Old Feb 9, 2005 | 09:55 PM
barthelb's Avatar
barthelb
Master
Just so you know our car has its true 1.1 gearing in 5th and dyno's should be run in 5th.
I just dyno'd my setup and put down 440.9 and 403ft.lb of trq @8.5psi
Old Feb 9, 2005 | 09:59 PM
webcarconnection
Yeah I know about the 1:1 on 5th I assume I will see better #'s on 5th
Old Feb 9, 2005 | 11:02 PM
phunk's Avatar
phunk
CJ Motorsports
Car looks great man!!!! Great peak #'s for 5.6 psi!!! If those cams are installed they are probably helping a bit.
Turbos seems like their spooling poorly tho... did you floor it at the begining of the pass or ease into the throttle?
I see you have the reflash from TS... are you running the E-Manage at all or have you removed it?
I bet you love your car x3 now!!!
Good luck with your project and future mods... its addicting.
Old Feb 10, 2005 | 03:47 AM
002-M-P's Avatar
002-M-P
One thing I'm looking at is your torque curve. Like phunk said, did you roll onto the power. Cause my dyno at 345rwhp put down over 300 lbft torque at 2500 rpm. You torque graph looks like it followed the hp curve alot.
Old Feb 10, 2005 | 07:25 AM
webcarconnection
Phunk:
Thanks for the reply, I went W.O.T. around 5000 rpms (ease into the throttle) thats why you see that up and down in the graph... I have to do it because when I went W.O.T. at 3000 the car star spining the wheels on the Dyno, I believe is from the shine tires that I have (Kit for tires) but my brother sit in the trunk and the car stop spining I know I can get better curve next time... I don't have the e-manange, only TS Reflash and yes I have the JWT cams.
002-m-p:
Yes I roll onto the power up to 5000 rpms...
