LockTite question - Vortech owners
Old Feb 14, 2005 | 04:26 PM
gersteinp's Avatar
gersteinp
Default LockTite question - Vortech owners
For the experts among you: do you recommend using a thread locker such as LockTite in the install of a Vortech supercharger bracket and/or blower? Which bolts would you apply LockTite? What color LockTite do you recommend (I've got red and blue)?
Thanks!
Old Feb 14, 2005 | 04:38 PM
backagain's Avatar
backagain
i used red on a certain bold that holds a pulley bolt in, holds just fine, i would recommend it.
Old Feb 15, 2005 | 12:17 PM
tig488's Avatar
tig488
no, i wouldnt put it on any except the one that holds the pulley on the backside of the blower, ive had mine installed for a while and i havent noticed any lose but that one. i put blue on it.
Old Feb 15, 2005 | 07:42 PM
gersteinp's Avatar
gersteinp
Do you used thread locker on any of the bolts attaching the mounting plate to the front of the engine?
Old Feb 16, 2005 | 09:23 AM
wfcall's Avatar
wfcall
On an ATI that I installed I used Bule(removable) on everything that iI would not be able to easily access for inspection and/or tightening.
Also-I used Red(removable w/application of heat) on ALL the pulley retaining bolts.
Also-Do the Votech pulleys press fit or slip fit?; The ATI's are a slip fit with no heat required to install them; I was not real comfortable with the key on the shaft doing all the work so I used Green locktite(680)-yes, green; that is made for slip fit pulley applicatons. It goes on the shaft before sliding the pulley in place and aids in a tighter fit. Claims to be able to fill up to a 5 thousandths gap.
I learned this the hard way because a slightly loose fit on a pulley (refering to the tolerance between the shaft OD and the pulley ID) caused the system to wiggle enough for the steel key to eat away at the aluminum pulley, it eventually spun the shaft and I had to send it back for free replacement
This is also aggravated by the fact that the aluminum pulleys expand at a greater rate than the steel shaft so it has a tendency to get looser when driven harder 'cause the tolerances open up and become even greater.:
Old Feb 16, 2005 | 02:05 PM
gersteinp's Avatar
gersteinp
The idler pulleys on the Vortech are plastic. I'd worry about trying to remove them with heat after applying red LockTite. I used blue on all the retaining bolts. I don't know if they're press fit or slip, but they are very smooth and there's no slop that I can detect. The bolts I think may most need thread lock are the ones that screw into the soft aluminum of the engine. Because you can't really torque these much, it's seems to me that I should be using LockTite on them. I'm not sure if blue is sufficient because of the heat in the engine area. But red might be impossible to remove without blowtorching all the hoses and wiring in the vicinity.
Anyway, thanks very much for your comments--very helpful.
Old Feb 17, 2005 | 04:42 AM
wfcall's Avatar
wfcall
Wow- i had no idea those were plastic; that totally changes things.
Probably Delrin, thats what the solid motor mounts on my VMAX are. Pretty indestructible but I don't think they are that heat tolerant.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
