Going Turbo...what else will I NEED?
Old Feb 17, 2005 | 11:11 AM
hndumafia's Avatar
hndumafia
sorry this is off-topic, but would it be dangerous to run a higher octane than the car is tuned for?
Old Feb 17, 2005 | 11:39 AM
zero2prove's Avatar
zero2prove
You can always run higher octane, especially on a FI car. Never run lower octane than what's you've been tuned with.
Old Feb 17, 2005 | 12:24 PM
phunk's Avatar
phunk
CJ Motorsports
i recommend running 100 unleaded at max if your tuned for 91-93. however there is no danger in higher octane.
Old Feb 17, 2005 | 06:29 PM
Enron Exec's Avatar
Enron Exec
Originally posted by one3502nv
The Unichip controls the boost for the APS TT kit.. Also, an oil cooler isn't really needed for the base kit since it comes with a finned larger oil pan... Also, we are running the Koyo radiator and it fits but was a pita to get it in their with the discharge pipes.... Alot of cutting of the shroud had to be done...
I had the same problem, even with thinner aftermarket fans. We ended up taking the radiator support off i think.
VampireG
May 27, 2005 08:27 AM
