cheap intercooler sprayer
Old Jun 5, 2006 | 03:37 PM
bobstaff147's Avatar
bobstaff147
Originally Posted by overZealous1
detonation is caused by heat. it is the air fuel charge igniting before it is supposed to thus if it happens before tdc you will be looking at some broken parts if it is a high hp motor. sounds like alot of guys are loosing their motors to detonation, but the stock Z motor already having 10.3-1 comp stock and tossing boost at it, you are raising your cylinder pressures way up. more cylinder pressure, more power, but more heat also from that power. compressing air generates heat (touch the pressure feed line on a running air compressor) thus the reason for intercooling.
Thanks for the description of detonation. I have a question you might be able to answer. If I install a supercharger and then have to drive it 4 hours to the nearest tune shop to make sure it's tuned OK, will I be able to avoid detonation (in the event the initial tuning is not quite right) by not pushing the engine too hard, or is it to risky to drive it that far even at moderate revs?
Thanks.
Old Jun 5, 2006 | 07:30 PM
overZealous1's Avatar
overZealous1
Thanks.
ya, this thread is over a year old, lol. but you should be fine during normal driving. just hold off the speed demons till you get the tune done. staying out of boost you should be fine. staying out of it could mean a happy motor and tons of miles, heeding to the speed demons and romping on it, could mean another motor and heaps o' money.
Old Jun 6, 2006 | 05:23 AM
HoldThisForMe's Avatar
HoldThisForMe
Ok so lemme ask this...I have a really good tune already. Say I want to WI it wouldn't that actually lower my HP? Would I have to get a retune or is that something I could change myself with the Utec? I REALLY dont wanna spend another 660 just for a retune lol
Old Jun 6, 2006 | 06:58 AM
roneski's Avatar
roneski
Originally Posted by JoeDirtPharmD
(4) Bottles of Heet (yellow bottle) @ $0.97/bottle from WalMart (100%); and
(1) Bottle of distilled water (same volume at one bottle of Heet):
Yields Water/Methanol 80%/20% mixture. Lasts me about 2 tanks of gas before the warning light comes on. Able to run 91 during PHX heat without detonation. I'm currently running an Aquamist setup.
At what ratio does the mixture become flammable?
Old Jun 6, 2006 | 07:23 AM
overZealous1
you definately would not have to get a full retune. the wi is just to bring intake and combustion temps down, so you can crank them back up by advancing timing and running abit leaner on your tune, hence more power. i personally am not a huge fan of it, kinda like having to keep filling a nitrous bottle, but unlike nitrous, when the tank is empty, you can blow your motor.
overZealous1
i have always heard a mixture of 50/50 for wi. but could be wrong.
Old Jun 6, 2006 | 08:44 AM
theking's Avatar
theking
This is also one of my reasons for not liking it. Another thing is that you can only run as much timing as your "hottest hole". Our IM isn't as bad as say a mustang 5.0 about these hot spots but you get the idea.
......i personally am not a huge fan of it, kinda like having to keep filling a nitrous bottle, but unlike nitrous, when the tank is empty, you can blow your motor.
Uriyo_
Sep 8, 2021 08:46 AM
Justin100
Nov 29, 2015 03:58 PM
