Can ANYONE brake-boost successfully ??
Old Apr 16, 2005 | 05:33 PM
slay2k's Avatar
slay2k
Default Can ANYONE brake-boost successfully ??
Why does our damn ECU disable the use of brake/gas pedals together at once ? It just cuts off the fuel to the engine! A friend with a turbo IS300 always lunges ahead of me from a roll because the kid has maximum boost when he lets off the brake, and I'm starting from zero.
Can't heel & toe either !?!?
This bothers me. Has anyone been able to do it, perhaps by modifying ECU or piggybacking or whatever ?
-slay
Old Apr 16, 2005 | 05:43 PM
booger's Avatar
booger
hook up a switch to your brake light fuze . I did it for the track
Old Apr 16, 2005 | 07:43 PM
G3po's Avatar
G3po
Default brake boosting
Originally Posted by slay2k
Why does our god damn ECU disable the use of brake/gas pedals together at once ? It just cuts off the fuel to the engine! A friend with a turbo IS300 always lunges ahead of me from a roll because the kid has maximum boost when he lets off the brake, and I'm starting from zero.
-slay
Try your emergency brake instead.
Old Apr 16, 2005 | 08:21 PM
KPierson's Avatar
KPierson
Should be an easy fix...
The break pedal has four wires on it (two switches I believe), I would imagine if you put a relay or two on these switches you will be able to bypass it.
Old Apr 17, 2005 | 07:31 AM
slay2k's Avatar
slay2k
This isn't something I wanna do myself... if I had to have a shop do it, what should my instructions be ?
Old Apr 17, 2005 | 05:36 PM
one3502nv's Avatar
one3502nv
We can do it... I have had a switch on my car for over a year...
Jason
jason@racemrc.com
Dr.Paulyy
Jul 29, 2019 07:45 AM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
z33z_nutz
Sep 23, 2015 07:22 PM
Shane86
Sep 17, 2015 05:33 PM
Ghalleo
Sep 11, 2015 03:20 PM
