greddy tt guys w/ e01 help
Old Apr 16, 2005 | 08:07 PM
5thgenluder's Avatar
5thgenluder
Default greddy tt guys w/ e01 help
Ok I've had the Greddy tt kit for about 6 months and its running great but... I've always have had a problem with boost in 2nd gear. If I'm cruising and all the sudden I punch the throttle in 2nd the boost spikes way up. At stock psi it wasn't bad but now that I raised it to 6.5 its horrible. I hit 7.5 constantly and have seen spikes in the upwards of 8.4 psi. Have any of you experienced this and found a solution? Any input would be greatly appreciated. And also it does both in auto or manual boost mode on the e01. Thanks again James
Old Apr 18, 2005 | 10:32 AM
5thgenluder
So nobody else has had this problem?
Old Apr 18, 2005 | 10:41 AM
narkotic's Avatar
narkotic
Do you have it set to auto mode?
Old Apr 18, 2005 | 10:48 AM
5thgenluder
Yes I usually use auto mode. Set at 6.5 psi gain 10 and start boost around 4.0
Old Apr 18, 2005 | 11:54 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
At low boost levels, the spikes are hard to controll with the e-01. if its just a momentary spike for less than a second, then I wouldnt worry too much. You might try increasing the gain, which will increase the sensativity of the solenoid adjustment. But this can also result in bigger spikes. Test it out and see.
Old Apr 18, 2005 | 12:40 PM
westpak's Avatar
westpak
SFZCC
It did the same thing to me in auto mode so I gave up on it and just went with manual mode.
Old Apr 18, 2005 | 01:35 PM
5thgenluder
thanks for the responces guys. westpak do u remember what your settings were?
Moncef
Jan 27, 2014 06:44 AM
