? Emanage vs SplitSec. Box ?
Old Apr 27, 2005 | 07:45 AM
Phatmitzu's Avatar
Phatmitzu
Default ? Emanage vs SplitSec. Box ?
I've noticed that some Vortech owners are changing out the SS box to the Emanage. I was wondering what are the advantages of the Emanage over the SS box?
Thanks.
Old Apr 28, 2005 | 09:54 AM
Phatmitzu's Avatar
Phatmitzu
Any Vortech people?
Old Apr 30, 2005 | 11:01 AM
Phatmitzu's Avatar
Phatmitzu
weekend bump...
Old Apr 30, 2005 | 11:13 AM
S12 driver's Avatar
S12 driver
Well couple people are running 550cc injectors with the SS box. So unless you plan on running even larger injectors, you shouldn't need to upgrade to eManage.
Old Apr 30, 2005 | 03:16 PM
luanda's Avatar
luanda
S12's right... the big reason I went with the Vortech tuner kit was to control larger injectors....I wouldn't try going to 550cc without an ECU reflash...I went with 440ccs which are just at the max 50% larger limit Emanage will support.
I think that the stock injectors are destined to an early demise given the duty they face when you add the vorteck kit, and if you suffer fuel starvation under boost then you may have detonation, and then it's over I'm afraid.
Old Apr 30, 2005 | 04:59 PM
booger's Avatar
booger
I was able to control the 550's with the SS box . But I thought the flash would be better . Ruff idle and all . Well Im having second thought about it . The SS box seems to have done just about as good as job as the flash . Will know more later after I get the blower back from Vortech
Old May 1, 2005 | 10:43 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The eMange is far more sophisticated than the SS box. The SS box uses MAF adjustment to enrich fuel, just like an SAFC. The eManage actually drives the injectors and the coils, by adding injector pulse width directly, or delaying the coil signal. The tuning software and also more powerful, and MUCH easier to use.
You can also scale injectors with one click, set MAF clamps, adjust for different MAP and MAF sensors, and a whole slew of other neat features.
The two systems are night and day in terms of functionality.
Old May 2, 2005 | 04:43 AM
booger's Avatar
booger
I may have to end up going with the E-manage . If my idle and starting doesnt get better after I check a few things . I may disconnect the SS box while I have the blower off and see if its the box it self that is causing the problem . The SS box pulls 1 1/2 degree's of timing just being hooked up and having the cams and 550 injectors , the timing being taken out by the box maybe the problem
Old May 2, 2005 | 05:34 PM
Phatmitzu's Avatar
Phatmitzu
I see. Thanks.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
