Gauges and the Stillen stage2 SC
Old May 4, 2005 | 06:43 PM
00Z's Avatar
00Z
Default Gauges and the Stillen stage2 SC
I just ordered the Stillen Stage 2 SC, I was told that I should get a boost gauge. I dont know much about boost gauges. Is this something I should look into with the Stillen SC?
Old May 4, 2005 | 06:52 PM
Phaneom's Avatar
Phaneom
With FI most people are have boost gauge, fuel pressure and a wide band O2 gauge. I'm not sure what the Stillen guys are running.
Old May 4, 2005 | 07:00 PM
zachcrosen's Avatar
zachcrosen
Get an AEM Wideband, a boost gauge and an EGT gauge(exhaust gas temp). I got Defi but you can go cheaper and get the Autometer ones.
Old May 4, 2005 | 11:50 PM
weslutes's Avatar
weslutes
Personally I don't run any guages but if I did, I would get a A/F(AEM wideband). That's it.
I've been runnin strong on 7lbs + n2o for a while. I tried a custom pulley(9-10lbs), & ever since the engine hsn't been the same.
If you don't plan on pushing the limits of your VQ like I did/do,then stick with the stage 2&3.
I planed for the worst, you should too.
Don't buy any headers or high flow cats.
Old May 5, 2005 | 05:45 AM
AdamDC's Avatar
AdamDC
The boost gauge is a really easy hook up for the stillen, just put a T in the vaccum line tube coming out of the passenger side rear of the plenum. Run it to the gauge. Done.
I think the important ones for stillen are the boost gauge (to make sure the SC is working properly) and a temp gauge in the IC reservoir (to make sure the IC is working properly).
On the other hand you can just go without gauges. Many people do just fine that way as the Stillen is a little safer than some of the other FI systems that need to be closely monitored.
Old May 5, 2005 | 06:18 AM
2003z's Avatar
2003z
All I have is a wideband O2, and its not really necessary. Thinking of addind a light that will tell me if the fuse on the intercooler pump is blown or not, since I've had 2 fail now (Stillen no longer uses this pump, so don't worry if you are a new orderer, its just my bad luck)
Bodyboarder81
Nov 2, 2015 12:17 AM
kyin
Oct 15, 2015 05:54 AM
Nicky R
Sep 20, 2015 01:05 PM
