A/F tuning (Vortech)
Old May 12, 2005 | 03:21 PM
Phaneom's Avatar
Phaneom
Default A/F tuning (Vortech)
I'm going to try to do a little bit of tuning. I was just wondering at what RPM should I start hitting 11.5? (maybe 12 to 5000rpm then 11.5 the rest?) If I'm going to be around 11.5 should I be pulling more timing or would the stock timing map be good? Also what would be the best way to adjust the timing, by psi, or RPM? If anyone could give me an example for both a/f and timing that would be awsome. I'm running the stock pully and hitting between 7.6 - 8 psi
Thank you
Old May 12, 2005 | 04:34 PM
booger's Avatar
booger
Pm me your email and I'll send you a file . It maybe a 3.12 pulley map , but you can get an idea of the timing
Old May 12, 2005 | 06:20 PM
SungNamZ's Avatar
SungNamZ
Bill, why don't you send me the "timing" map by e-mail also. I think I finally have someone here that knows or is prepared to learn R4. Thanks! Ron
Old May 12, 2005 | 06:50 PM
freezeg35's Avatar
freezeg35
Boog, can i get a copy of the 312 map as well please.
email: freezo@shaw.ca
TIA
Old May 12, 2005 | 07:16 PM
booger's Avatar
booger
On my way out the door . Will send files again in the morning
Old May 13, 2005 | 03:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Phan, I assume you are doing this on a dyno..right?
I think its really cool when people try to learn how to tune. I'd also suggest using 100 octane fuel for your tuning, especially if its your first time with this setup. It adds a signficiant level of safety margin as you run through the RPM range.
Personally, I would be shooting for 11.5:1 as quickly as possible...somewhere around 3500rpm.
What type of fuel are you planning to run on a daily basis? For timing, a good starting point is roughly 18 degrees of total advance at WOT. Since the base timing on the 350Z is about 24-26degrees at WOT, you would need to subtract 6-8 degrees of timing. To much timing retard is just as dangerous...if not more dangerous that too little.
Just be careful..mistakes can cost you thousands of dollars if the engine is damaged.
Old May 13, 2005 | 04:42 PM
freezeg35's Avatar
freezeg35
Speaking of timing, does anyone think its possible and safe to retard more timing than the stock vortech setup does. The reason i ask is im in canada where every gas station has 94 octane, the only grade i use, and ive heard that canadian gas is much better quality than american. Just a thought.
Old May 14, 2005 | 05:39 AM
Phaneom's Avatar
Phaneom
Yes I would like to tune it with a dyno. I was just wondering if anyone tuned without a dyno? And how did it go?
Old May 14, 2005 | 08:01 AM
zimbo's Avatar
zimbo
When I had the Vortech supercharger I did some limited tuning on the street after changing from the stock pulley to the next lowest one. However, I had a wideband O2 sensor I could log to my laptop, I was pretty familiar with the R4 software and with my car by that time, and all I really did was "coarse-grained" tuning to get things close in anticipation of doing fine-tuning on the dyno later on.
Old May 16, 2005 | 01:49 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Actually,
You could retard less timing with a higher octane gas and make more power.You are sort of thinking of going in the wrong direction.
BTW,
I also have a good solid Vortech map for the FTC in which we made 399.5 horsepower at the wheels (on a Dyno Dynamics) on 91 octane pump gas @ 10.5 psi(2.75 pulley).So this map is good upto this psi of boost.
Old May 16, 2005 | 02:50 PM
Sharif@Forged
Forged Performance
You can get a rough WOT tune via street. But its challenging..if not impossible to hit all the various load points. Also, it is very dangerous....as your speeds need to illegal in almost all cases.
Do it on the dyno....
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
