JWT TT news w/ dyno
Old May 21, 2005 | 10:58 PM
Rayden2001's Avatar
Rayden2001
Sure...I order my turbo kit and now Jim wolf decides to release his kit soon.
Old May 21, 2005 | 11:07 PM
phunk's Avatar
phunk
CJ Motorsports
definatly a valid concern... something only testing could determine... and I am no engineer, but personally I am not visualizing that problem happening.
Old May 21, 2005 | 11:12 PM
UnderPressure's Avatar
UnderPressure
JWT should have/will put alot of time into the development and testing. Lets just hope they've done their homework, and come out w/ a complete kit.
btw, wtf are we doing @ 3:15am posting? lol
Old May 21, 2005 | 11:15 PM
phunk's Avatar
phunk
CJ Motorsports
funny cause I was wondering the same thing in my head... 2:15 for me... g/f is passed out on the couch next to me... and i think i woke up at 3pm today (had a long b/d party for a friend friday night) so i still got a while to go!
Old May 22, 2005 | 12:52 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
yah...crazy isnt it
Old May 22, 2005 | 05:15 AM
kjbalto's Avatar
kjbalto
Can anybody comment on what it would sound like? JWT says there is no blow off valve, instead they will have dual bypass valves that recirculate. Will this make any noise at all like a blowoff valve or will it be quiet as hell? My friend's GTI has a stock bypass valve and he bought a diverter for it. When he put the CAI on it sounds like he has a blowoff valve on there. When he revs the engine it lets out a loud wooooshhhh.
Old May 22, 2005 | 08:41 AM
Rayden2001's Avatar
Rayden2001
Sorry, off the topic but Underpressure what kind of trailer do you have for your Z? I would pm you but I kept getting an error
Old May 22, 2005 | 09:15 AM
UnderPressure
Got rid of that trailer long ago. I have a 16ft Featherlight for work and a 28ft enclosed for play.
Old May 22, 2005 | 09:18 AM
CESAROTORRES's Avatar
CESAROTORRES
Unhappy
Originally Posted by phunk
I am very surprised to see the power they are pushing, last time I talked to them they didnt sound as if they were going to go for as much.
I am extremely confident that this will be the cleanest running kit for the Z possible.I want you guys to pay special attention to one really big deal with this kit...
The MAF sensor is located before the turbochargers. This means this car will be running OEM clean to perfection. There is NO POSSIBLE way to run a car cleaner, more consistent, and safer then with a MAF sensor located directly after the filter. MAF sensors were never engineered to operate in high pressure enviroments, and you will never see a factory turbo car with a MAF sensor in the charge pipe... how JWT did it is how all the OEMS do it.
Look at it making full boost around 3400 rpm... this is the more responsive of any kit I have seen on a Z... I have seen some Greddy and APS come in at 3800 which is definatly early enough anyway, but another 400rpm in such a low rpm already means they got some serious response here.
The peak #'s are right on par with the other kits for its ammount of boost so far... that means the turbos must still have quite a bit left in them... but I dunno about making the crazy HP that a greddy or aps kit can support. Then again, I am sure that JWT could very easily provide you with a larger turbo when you buy the kit, considering they have an entire lineup of their own.
Now here is a kit that I cannot wait to install. Could this be the most engineered kit on the market? I guess we will have to wait for more details... I want to know more about their fuel system... so far every other kit has left much to be desired in either completeness or quality (not that i mind since i manufacturer and sell fuel systems)... but if it can make that kind of HP out of the box and has a fuel system that I like, that would be very nice.
I also want to know if that car is running on a remapped ECU or if there is a piggyback in there. If this car is on a remapped ECU, that means that with the MAF sensor where it is, that this car will be tuned precisely like an OEM Z. Every single high HP Z running a piggyback that I have seen on my dyno and from graphs posted on the net produced choppy graphs, Greddy, APS, Vortech is all I have run over here, but each one had the same symptoms at higher power.
I already have turbos so I am not holding my breath, but I am definatly eagerly awaiting to see the rest of the details on this system and i cant wait to get my hands on one for install.
very kick ***.
I know that Greddy stock fuel system has left much to be desired in either completeness or quality, but I tought that the APS TT has taking care of this on their fuel system.
Cesar
Orlando FL
Soon power by APS
Old May 22, 2005 | 09:31 AM
Rayden2001's Avatar
Rayden2001
Thanks
Old May 22, 2005 | 11:17 AM
sentry65's Avatar
sentry65
the burninator
i just wanted to post this link in case anyone missed it - it's the G35 version of the JWT design
http://www.jimwolftechnology.com/TTINFO/ttindex.htm
and here's an overlay graph I made of the APS kit at 9.2 psi with test pipes and exhaust vs stock JWT TT that I posted in another thread
Attached Thumbnails JWT TT news w/ dyno-apsvsjwt.jpg
Old May 22, 2005 | 11:30 AM
phunk's Avatar
phunk
CJ Motorsports
Cesar
Orlando FL
Soon power by APS
Greddy doesnt even come with a fuel system to complain about.
UnderPressure
Comparing dyno pulls from different dyno mfgs is not an valid comparison. The only way to compare the 2 runs would be is they were done on the same mfg dyno, and even then, unless they were run w/ the same parameters the runs would not be comparable.
What would be more telling would be to look @ the boost vs rpm graph. This would show response and performance.
Good work on overlaying the graphs though.
Old May 22, 2005 | 11:34 AM
Speedracer's Avatar
Speedracer
Default Don't forget, however......
The dyno plot for the JWT indicates a boost pressure of 7.4-8.2 PSI which is higher than the production spec of 6.8 psi.
Old May 22, 2005 | 11:40 AM
sentry65's Avatar
sentry65
the burninator
yeah I know the dynos are different and in different climates etc - CA vs Australia, but thought it was interesting to look at nonetheless. Makes you wonder what the JWT graph would look like with test pipes and exhaust at 9.2 psi...
Old May 22, 2005 | 11:51 AM
UnderPressure
The telling information would be to look @ boost vs rpm. Those are numbers that any dyno can measure and are not able to be manipulated by the end user. Well @ least not easily. That would be more of an apples to apples comparison.
Old May 22, 2005 | 12:03 PM
phunk's Avatar
phunk
CJ Motorsports
This has always been one of my major defenses for the Dynojet 248 graphs... the dynojet may not be the most high tech dyno out there... its actually the most LOW tech dyno, but there is not a user adjustable setting here that will allow me to effect its output, the only thing i can do is change around correction factors. There are no parameters that you speak of on the dynojet, which is why its the dyno for preference when it comes to internet based comparisons between one car or another.
There was a thread where you mentioned that dynojets have higher numbers compared to the standard settings defaulted in these load dynos, which i bet is true coming from someone as qualified as you. But then at the end of that post you made you commented on how all the high tech load dyno operators can easily effect the output numbers to their favor, which is why I try not and put too much consideration into graphs produced on those type of dynos when I want to compare it to the performance of my own car.
Even looking at the graph that JWT posted, there is no freaking way that car is making 380ft lb of torque at 2000 rpm!! That is why in my post above where i mentioned this graph I only commented on at what RPM you can see that it acheived max boost.... just like how the SGP racing dynopack graph of Abdullas car shows it climbing 210lb ft from 4000rpm to 4500rpm... and that is just NOT AT ALL the boost profile of a greddy kit car, on their dynojet graph of that car you see it climb only 50lb ft from 4-4.5. This is much more realistic as to how that car will drive on the road... On the road you have your load coming from 3 major sources... the weight of the car (which is STATIC), the drivetrain, and the aero... on the dynojet you get 2 of those.... you get the weight of the rollers (A high STATIC load) instead of the weight of the car (which for most cars is actually less load and will make the turbos spool up slower and produce less boost then they do on the road), the drivetrain (including how your wheels/tires and alignment are effecting the power your putting down.. most people do not understanding how much HP you can really eat up with an aggressive alignment and sticky tires... my car looses a lot of power when I run it on the dyno with the drag radials versus my street tires).... the only thing the dynojet doesnt include is the aero but the resistence of that is not something you should judge against your vehicles output to the wheels.
The load based dynos have no mass to them at all, meaning the load provided is by a programmed brake and its not NEARLY static. I have witnessed pulls on a load based dyno and its almost annoying how you can hear the load change thruout the run... while tuning this is probably very useful, but when you want to get a realistic output graph from the car there is no way to possible have a less accurate graph then to be having the load constantly changing. There is a LOT OF WORK done by the load dyno before you get some type of calculated output number which may or may not even mean anything at all. With a dynojet there is nothing but a massive weighted roller and there is no arguement that it takes a given ammount of energy to spin that up to speed at a given rate. Therefore there is absolutely nothing one can do to effect the numbers.... other then putting the atmospherical temp sensor in an oven so that your SAE numbers overcorrect... but thats a lot more work then a few wrong keystrokes by a dyno operator that probably never read the 300 page manual for his load dyno.
Underpressure... being that you are a sales rep for a Dyno Dynamics, I would love to get in a nice long dyno arguement with you, maybe we should take it PM or voice. I have never tried to preach that the dynojet is a very nice dyno... but I will argue to the death that there is no better dyno to use for comparisons purpose and for consistencies sake... but maybe YOU could teach me a few things... I have known for a long time the benefits of ease you get when TUNING a car on a load dyno... but in every dyno arguement I get in, consistently and compariability (is that a word?) are what I defend.
Old May 22, 2005 | 12:11 PM
  #38
phunk's Avatar
phunk
CJ Motorsports
I dont agree, I have watched a load based dyno start a run, then hold the car at a specified RPM for a few moments (which would be like brake boosting a laggy turbos to spool it before you race) and then "release" for the run. There is no doubt in my mind that this is going to build up turbine speed at unrealistic rates and taint the output graph.
Old May 22, 2005 | 12:14 PM
  #39
UnderPressure
I agree with some of what you say and disagree w/ some other items.
I'll be happy to talk dyno w/ you off thread.
The only points I have made in this thread are just about the comparison between dynos, and to make sure that people do not misread/misinterpret graphs. Just trying to educate people, not saying anything is better or worse.
Back to the thread, sorry for the hijack.
Charles, Check your PM's
Old May 22, 2005 | 12:18 PM
  #40
phunk's Avatar
phunk
CJ Motorsports
sounds good... ill PM you later about it.
aww, i love hijacking.
