See...it can be done.....
Old May 23, 2005 | 11:19 AM
Speedracer's Avatar
Speedracer
Default See...it can be done.....
If anyone anyone has read the latest Car & Driver, they did a test on the new Audi A4 2.0T.
From the factory: 10.5 compression and 12lbs boost
Old May 23, 2005 | 11:35 AM
zuzoshin's Avatar
zuzoshin
I looked it up on the Audi website and you're right! I guess Peter was right about having higher static compression ratio with a turbo. I can't wait to get my APS TT this fall...
Old May 23, 2005 | 11:41 AM
S12 driver's Avatar
S12 driver
The Audi can do that because it has direct injection, when the gas is injected directly, it has a cooling effect to supress detonation.
Old May 23, 2005 | 12:25 PM
sentry65's Avatar
sentry65
the burninator
does the VQ35 have direct injection?
isn't the VQ35 just a regular fuel injection engine like any other fuel injected engine or is it like the audi?
Old May 23, 2005 | 12:57 PM
Lorca@Z1's Avatar
Lorca@Z1
Gas is very ineficient for cooling, but it is generally the only thing available to the OEM that is idot proof for the end user. Check out water injection H2O
Thats how I plan to get to 12PSI
Old May 23, 2005 | 01:08 PM
jeffw's Avatar
jeffw
Direct injection makes pre-ignition not much of an issue. It's also supposed to allow for better mixing of air and fuel.
Jeff
Old May 23, 2005 | 05:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
VQ35 does not have direct injection. Direct Injection squirts the fuel directly into the combustion chamber vs. spraying the fuel into the intake track. Its an awesome design, and minimizes the changes of detonation, and allows OEM's to run richer CR's for better emmisions and more power...with less chances of knock.
tioga
NISMO 350Z
48
Jan 21, 2014 06:54 PM
Z You Later
Sep 28, 2013 08:51 AM
altima02dub
Nov 16, 2012 03:01 PM
16psibrick
Audio Builds
Dec 11, 2007 03:28 PM
