True Dual 2.5" Exhaust Options?
Old May 30, 2005 | 07:27 PM
cjb80's Avatar
cjb80
Default True Dual 2.5" Exhaust Options?
I am looking for a true dual exhaust for the Z which is 2.5" all the way back. As far as I know, APS is the only option, are there any other exhausts available? How do they compare?
Thanks!
Chris
Old May 30, 2005 | 07:46 PM
sbcbaseball's Avatar
sbcbaseball
Stillen but at one point the pipes do "X"
Old May 30, 2005 | 09:35 PM
phunk's Avatar
phunk
CJ Motorsports
HKS has a true dual 2.5" also, just put one on a customers car and it sounds INCREDIBLE, has titanium tips, and is full polished stainless, it fit up perfect, and the tips have about 1" of adjustment to suit your tastes for how far they stick out. part # 32009-BN001 i believe... its a bit expensive tho with MSRP at 1895... you might be able to find it for around 1500... its the only dual 2.5" that I know of that uses a twin straight thru canister mufflers rather then a stockish looking one like the APS and my borla.
Old May 31, 2005 | 02:18 AM
baptist's Avatar
baptist
Whats APS, 2.25" ?
Old May 31, 2005 | 05:25 AM
Lorca@Z1's Avatar
Lorca@Z1
We have seen the best TT gains by far on the Stillen unit, but have not had the opportunity to try an HKS yet.
Old May 31, 2005 | 05:36 AM
xxlbeerZ's Avatar
xxlbeerZ
SSR Engineering can make you whatever you want for ~$700-800.
Old Jun 1, 2005 | 08:48 AM
cjb80's Avatar
cjb80
So I am leaning towards the APS 2.5" true dual exhaust at this point, with test pipes.
I have been thinking about this subject alot though. I built an S2000 which pushed 559 rwhp at 23 psi of boost with a 3" exhaust system. So that is 2 liters, 4 cylinders being pushed out of a 3" pipe at ~9400 rpm. I am shooting for similar power, with less boost, and pump gas.
Now I have a 3.5 liter motor with two 2.5" pipes, so that's 1.75 liters with 3 cylinders out of 2.5" at say, 7000 rpm. I am not sure how much the max RPM of the motor matters, or the number of cylinders in this scenario... but:
The equation for an area of a circle is a = (pi)r(squared) -- however you write it out.
The area of a 2.5" pipe is 4.90625", the area of a 3" pipe is 7.065". The difference between the two is 31%. The difference in displacement from 2 liters to 1.75 is only ~13% however, so the 2.5" pipe is still somewhat smaller - relatively - even though there are two of them.
The question is though will the two 2.5" pipes be enough for 550 rwhp? Will it be enough for 600 rwhp? I am not really interested in much more than that honestly...
What do you guys think?
Thanks
Chris
Old Jun 1, 2005 | 09:00 AM
Lorca@Z1's Avatar
Lorca@Z1
Thanks
Chris
We routinely push 600+ rwhp through dual 2.5" pipe exhausts on our Z32's (3 liters), so I don't think 2.5" pipe will be the limiting factor in your case.
Old Jun 1, 2005 | 09:36 AM
phunk's Avatar
phunk
CJ Motorsports
<--573 rwhp at 14 psi thru twin 2.25"
Old Jun 1, 2005 | 09:43 AM
sentry65's Avatar
sentry65
the burninator
for comparisons sake, what's people's opinion on one of the bigger 3" Y pipe design like the nismo or fubijitso for FI?
the area of dual 2.5" exhaust = 9.8125"
single 3" = 7.065"
Old Jun 1, 2005 | 11:19 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Realisically, on our 3.5L V6, anything above 2.5 inch true dual will provide no benifit.
Like Phunk, I am also running mid 500'whp range through the Greddy Evo2 exhuast, which is 2.25 at best....
Old Jun 1, 2005 | 06:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
don't forget the Ultimate Racing dual setup...
dual 2.5 piping throughout, mufflers are 2.5 inch inlets as well with 4 inch tips
Old Jun 1, 2005 | 09:19 PM
APS's Avatar
APS
Chris in terms of exhaust system performance on a turbocharged engine you really need to look/measure the exhaust back pressure - an ideal exhaust system should have near zero exhaust back pressure at peak power.
Exhaust tube diameter is always one important factor to consider though in reality you need to consider tube diameter and muffler flow in combination as both of these parameters impact on gas flow and exhaust back pressure, hope this helps.
Peter
Old Jun 1, 2005 | 10:12 PM
350Zteve's Avatar
350Zteve
Thanks!
Chris
DC Sports is 2.5" True Dual all the way
Old Jun 1, 2005 | 10:30 PM
Gman2004's Avatar
Gman2004
How about two 3" cut outs? Got this off another post. Check out the vid on the bottom of the page right side. looks pretty cool.
http://www.atpturbo.com/root/releases/release091004.htm
Old Jun 2, 2005 | 12:17 AM
phunk's Avatar
phunk
CJ Motorsports
IMHO the 350z is already a fairly complex vehicle. added complexity leaves more room for problems. gadgets should be avoided by all costs... i would rather just get a decent exhaust that will allow me to make good power all the time... to add in cutouts sounds like a pain, they might leak? i would rather just remove my exhaust before going to the track and save weight while im at it before running a cutout... thats just me tho... to each their own. i keep my exhaust on anyway... i like to hear what going on with the engine if i can.
Old Jun 2, 2005 | 12:20 AM
Gman2004's Avatar
Gman2004
I wouldn't have the ***** to try the cut outs. You could take them off if it was too loud, but your exhaust would be all hacked up.
Old Jun 2, 2005 | 02:41 AM
APS's Avatar
APS
The question is though will the two 2.5" pipes be enough for 550 rwhp? Will it be enough for 600 rwhp? Chris
Chris is you're really thinking about 600 WHP then a true dual 3 inch system would be the ideal exhaust solution - I believe you will find the exhaust back pressure will be very high at 600 WHP on a true dual 2.5 inch exhaust and this will be power limiting on the VQ engine.
Peter
Old Jun 2, 2005 | 04:15 AM
kudos's Avatar
kudos
619whp at 17psi, with helix test pipes, JIC ypipe and a custom 3" single exhaust.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
