Test pipes and EGT's
Old May 31, 2005 | 07:42 AM
booger's Avatar
booger
Default Test pipes and EGT's
Just wondering if any one knew if running test pipes verses Crawford cats , would lower EGT's any ? My thinking is if the exhaust can exscape faster , temps wouldnt build as high . ANY ONE ?
Old May 31, 2005 | 01:41 PM
zachcrosen's Avatar
zachcrosen
I thought that higher temps helped the gases exit quicker. I thought that was one of the reasons why people were wrapping their exhaust components.
Old May 31, 2005 | 03:15 PM
PoWeRtRiP's Avatar
PoWeRtRiP
most people record their egts directly off of the manifolds. since this is pre-cat there is no real way to compare. but yes having cat will actually lower the temp of your exhaust, because of all the excess honeycomb material absorbing the heat. a common trick that people use to fool the o2 sensor in the test pipes is to pull it out with washers so its not directly in the heat stream.
Old May 31, 2005 | 03:26 PM
booger's Avatar
booger
I have my probe about an inch away from the exhaust port . I was thinking of going back to test pipes and just wondered if anyone knew . The car is loud enough with cats on .
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
