2005 Z Enthusiast Rev Limiter going up to 7100????
Old Jun 1, 2005 | 09:52 AM
mrtomcat's Avatar
mrtomcat
Default 2005 Z Enthusiast Rev Limiter going up to 7100????
I posted this in the general forum but hardly anyone ever responds there....so here it is again:
Ok, I'm confused, I read that the 05 track and anniversary editions have the raised limiter to 7100rpm but after driving in my new enthusiast (build date Jan 2005) I pushed it up and the limiter does not kick in till 7100 rpm as well....which is great but very unexpected.
Can someone shed some light on this?
Old Jun 1, 2005 | 10:08 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
did you free rev it? Or slighly rev in gear....until you reached the limit?
NO idea..but maybe all of the 05's have the rev limit increase?
Was your ECU reflashed without your knowledge?
Old Jun 1, 2005 | 10:11 AM
barthelb's Avatar
barthelb
Master
He probably has the 298hp version which red lines at 7100 like in the new G35.
Old Jun 1, 2005 | 10:21 AM
mrtomcat's Avatar
mrtomcat
I was at half throttle in first gear going all the way up.
The car was brand new when I bought it from the dealer (30 miles on it)
is it different depending on how hard you hit the throttle???
I was going to get my ecu reflashed (L-Spec) today but because of this I canceled. I'm going to the track tomorrow and will find out for sure.
(too many cops in my neighbourhood to do a full run on the streets)
mrtomcat's Avatar
mrtomcat
I thought these are only in the Track and Anniversary Editions???
Old Jun 1, 2005 | 10:53 AM
del105's Avatar
del105
15 f125
I think your rpm gauge may be off. Mine looks like it hits fuel cut around 7k too but the dyno is telling a different story.
Old Jun 1, 2005 | 11:28 AM
VR3's Avatar
VR3
Yes, only in the Track and Anniversary Editions have 298hp & revised rpm limit. it's on nissanusa.com. As well as the MT G35.
Old Jun 1, 2005 | 12:07 PM
mrtomcat's Avatar
mrtomcat
I don't think the gauge is off because I hooked up my G-Tech which was calibrated on my old 04 Track and it is right on with the new car.
Something else is going on here
I have not seeing anything in the manual or at a nissan site that states where the limiter kicks in. They could have easily decided to up it on newer 05 models. Remember the early 04's didn't have widebands either...
Old Jun 1, 2005 | 03:17 PM
booger's Avatar
booger
Your tach maybe off . Mine is off by 500rpm .
Old Jun 1, 2005 | 04:26 PM
mrtomcat's Avatar
mrtomcat
let's just say for arguments sake that the Tach is off, how could I find out for sure and get it adjusted?
Old Jun 1, 2005 | 04:48 PM
booger's Avatar
booger
That I wouldnt know how to adjust . I know mine is off because of my datalogger and the Spit Second box show the same rpm and boost levels at the same place , but Im seeing 500rpm less on the tach
Old Jun 2, 2005 | 09:18 AM
nearly zer0's Avatar
nearly zer0
see how fast you are going at redline in 2nd. you should be able to tell if it is off by your speedo. i know there is a chart floating around for reference.
Old Jun 2, 2005 | 10:47 AM
mrtomcat's Avatar
mrtomcat
I tried last night again under more load and the limiter kicks in about 6800 - 6900 rpm...so I think my tach is probably off a bit.
I rescheduled my apointment with technosquare to get the lspec reflash done next week.
thanks for the input guys!!!
May 30, 2017 03:28 PM
kyin
Oct 15, 2015 05:54 AM
