Possible crank angle sensor wire problem?
Old Jul 28, 2005 | 04:59 PM
7 eleven's Avatar
7 eleven
Originally Posted by Phatmitzu
I installed the CAS wires last week. Other than the first couple of cranks the car/ECU is having problem maintain idle, everything was running fine the whole week...until today...
I was at a stoplight heading home. After the light turned green I proceeded to move forward. All of a sudden the car started to choke. I immediately turned off the AC and pulled my car to the side. The car will start choking after ~2500 rpm. Even if I free rev the engine it wont go pass ~2500rpm. I noticed that the car is running extremely rich. A/F was at ~9.x:1 at idle(was ~14.5:1) and ~10.x:1 when I tried to gas it. I turned off the engine didn’t know whats wrong with it. I let it sit for about 3 mins and started it up again….normal. Revs normal, A/F reads normal. I then drive the car home without any issues.
I suspected the CAS wire because that is the only thing I’ve installed in the past couple of month.
Anyone knows what might be the problem?
I've got 5 bucks on the MAF limp mode. All your symptoms match it word for word. Check the wiring at the MAF for damage. If it happens all you have to do to clear it is turn off the car for 20 seconds then turn it back on.
Gary
Old Jul 28, 2005 | 06:32 PM
kcobean's Avatar
kcobean
Originally Posted by BPL
I've been driving with the shielded CAS for over a month now and no problems here.
Ditto-ish. Hasn't been quite a month yet, but no CAS issues.
Old Jul 28, 2005 | 10:54 PM
Z BOY's Avatar
Z BOY
Engine mods are
K&N Typhoon CF Intake
Kinetix V4 Plenum
Kinetix HF Cats
UR Crank Pulley
Nismo Headers
Nismo Flywheel
Nismo Clutch
JIC Y-Pipe
Power House Amuse R1 Titan Exhaust
Apexi SAFC-II
Zeitronix A/F Wideband
Shielded CAS Wires
Pro-1 Torque Damper
S2000 Engine Start
B&M Short Shifter
phat, i don't see any fi on your mods list. why would you need an upgraded cas without it?
Old Jul 29, 2005 | 06:08 AM
Phatmitzu's Avatar
Phatmitzu
Cuz I have Turbonetics sitting in my garage right now
Was just getting the reinforcement parts installed before I put the turbo on.
Old Jul 29, 2005 | 06:55 AM
kcobean's Avatar
kcobean
I'm curious, are you planning on doing a custom TS flash to support your breathing mods? Your car will almost certainly run lean with all the extra airflow coming into the standard maps. I think if I were in your shoes, I'd be planning on either a customer TS reflash or a piggyback to get some extra fuel into that beast.
MIAPLAYA, what's your take on this?
Old Jul 29, 2005 | 07:10 AM
Phatmitzu's Avatar
Phatmitzu
I got that covered
I will be having the ECU reflashed with the standard reflash that comes with the kit, but I will have GReddy emanage installed and dyno tuned. I will run the stock setup for a month or so for the ECU to settle. Then I will be installing the 440 injectors with the AAM fuel return system and the GReddy EO-1 along with some other goodies...then of course...dyno tune again.
Uriyo_
Sep 8, 2021 08:46 AM
