FI on an AWD G35?
Old Jun 5, 2005 | 08:23 PM
BluZee's Avatar
BluZee
Default FI on an AWD G35?
Has anyone put a supercharger or twin turbo setup on an AWD G35? Just curious. (I already used the search function)
Old Jun 5, 2005 | 08:30 PM
g356gear's Avatar
g356gear
If you look under the g35x, the entire transmission, front subframe, and exhaust are completely different from any 350z or g35 coupe, 2wd sedan. For any of the TT kits the piping would all have to be changed to route around the extra obstacles. The only kits I see maybe working are the centrifugal blower kits (ATI, Vortech) or the Stillen. ECU and wiring would of couse be different so that may ultimately become the largest hurdle. There are extra lines and a cooler in front of the radiator for the AWD system as well which may cause intercooler clearance issues. With enough money though...anything is possible.
Old Jun 5, 2005 | 08:41 PM
thawk408's Avatar
thawk408
That would be so pimp to have a twin turbo g35x or do a Vortech or Procharger on a built motor....mmmmmm
Old Jun 5, 2005 | 09:16 PM
phunk's Avatar
phunk
CJ Motorsports
AWD is cool, Automatics are cool... but AWD Automatics... I just dont know. Could you get a good launch with that car? I just dont have enough experience building automatic cars to know enough about upgrades for them and what kind of options exist.
Old Jun 5, 2005 | 09:20 PM
g356gear's Avatar
g356gear
Man....there is so much extra junk under there it's crazy!! The front differential is mounted off the side of the upper oil pan and the front drive axle to the drivers side goes straight through the pan to the other side of the block!! 300 extra lbs of fat!!
Old Jun 6, 2005 | 05:46 AM
BluZee's Avatar
BluZee
Damn. I didnt realize that the G35x was that different. Maybe somebody will put a Vortech or something on one just to see what happens.
Old Jun 6, 2005 | 08:27 AM
kopo's Avatar
kopo
There is a guy in chicago with a g35x and a stillen stage 2 I believe + a ton of other upgrades. Everything seems to be working fine last time I talked to him.
JjL
East Canada
Jun 12, 2019 03:04 AM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
seagrasser
Oct 11, 2015 03:27 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
