Plug gap
Old Jun 8, 2005 | 11:28 AM
1 2 NV's Avatar
1 2 NV
Default Plug gap
What is everyone running the gaps on there plugs at? I am getting a SES for multiple misfires and I am thinking its because I didnt gap the plugs. I went with 1 step colder irridim plug. Im not sure if that is it though cause I dropped the stockers back in and came up with the same thing. Any suggestions?
Old Jun 8, 2005 | 11:29 AM
MIAPLAYA's Avatar
MIAPLAYA
hmm that interesting.... Even with the stocks it came back after clearing it?
taurran's Avatar
taurran
Are you running NGK or Denso plugs?
Old Jun 8, 2005 | 11:37 AM
SirJonnyWispit's Avatar
SirJonnyWispit
well it probably isnt much help but i put 2 step colder denso iridiums in mine and for the 10-15 minutes i got to drive it no codes came up and it seemed to be running extremely smooth... and i left them gapped as they came... i cant remember the gap but they all came the same.
Old Jun 8, 2005 | 11:41 AM
1 2 NV's Avatar
1 2 NV
Ngk LFR6AX-11 or something like that. They are at home so I don't now for sure but that is it, I think. MIA, yeah I disconnected the battery for 15 minutes and connected it back up. When I started the SES light wasn't on. But after a few minutes it popped on. Than this morning after getting to work I was sitting there letting it cool down(no turbo timer right now) The SES light flashed 5-10 times which meens it just misfired while I was sitting there at idle. But it seems to run great at normal driving speeds. I have that narrow band Defi-D a/f gauge and at idle it sits around 14.5-15.0 and about every 5-10 seconds it will dip to 16-16.5 I was thinking that maybe I was just running rich at idle and maybe thats what was causing my misfires but if that gauge is even remotely correct that would not be the case. I know narrow band is really only worth a damn at WOT, if that.
Old Jun 8, 2005 | 11:42 AM
taurran's Avatar
taurran
Same. I'm running NGK Iridium 1-step colder plugs, and we didn't adjust the gap on them at all. No CEL. hmmm
Old Jun 8, 2005 | 11:45 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Check all your plugs on the coils. One probably is not connected tight enough...
MIAPLAYA's Avatar
MIAPLAYA
That is interesting. The lean spike at idle would indicate the ECU is advancing the timing momentarily but why I dont know. It could be that the car is dumping a little extra fuel occaionally and therefore it is forced to add extra timing to resolve it. I will get a hold of Brad and Jahme today and see what they think.
Old Jun 8, 2005 | 11:52 AM
1 2 NV's Avatar
1 2 NV
Once again MIA..........Thanks.
Kyle, the coil gets bolted in the valve cover. So you cant really controll how far down it goes on the plug. I don't see how it could not be on the plug.
Old Jun 8, 2005 | 11:59 AM
MIAPLAYA's Avatar
MIAPLAYA
I think he means the electrical connectos that go to the coils....a good place to check but since you didn't remove them it should be fine. Like I said I will call Brad and Jhame and see if they can come up with anything. In the meantime have you tried going to Autozone yet to clear it. Sometimes the codes are stored in the ECU even though they do not show and it could be frekaing it out. Try and clear it via the ECU reset from TS or Autozone. I will do my best to get an answer for you.
Old Jun 8, 2005 | 12:07 PM
1 2 NV's Avatar
1 2 NV
It was getting late last night so I figured I would hit Autozone up in the morning on the way home from work. Its too early and they aren't open when I am on the way to work. I cant try the reset till tomorrow morning also cause I found a small oil leak(size of a silver dollar) this morning before leaving for workcoming from the new rtv seal. So I already drop the pan and stripped the old rtv off applied new rtv. I'll drop oil in it tomorrow morning. You know if it aint one thing its another. Thats alright I WILL get all together, it will take alot more than what has happened so far to detur me from all this.
Old Jun 8, 2005 | 12:20 PM
MIAPLAYA's Avatar
MIAPLAYA
12 I just talked to Brad at Turbonetics. He is going to talk to Jhame right now about the misfire. I should be getting an answer from him later today on things to look at. He is making this a priority along with the issue that sirjohnny had. I will reply about that in his thread.
Old Jun 8, 2005 | 12:42 PM
1 2 NV's Avatar
1 2 NV
Thanks MIA, I cant wait to get this thing nailed!!
Old Jun 8, 2005 | 12:43 PM
ImportPartsPro
Correct...if the electrical connector is not making a good connection it will misfire and throw the code. Even if they were not disconnected I would check them since you moved them around.
Old Jun 8, 2005 | 12:49 PM
1 2 NV's Avatar
1 2 NV
I'll check it out tomorrow when I get home. Thanks for the suggestion.
Old Jun 8, 2005 | 01:17 PM
MIAPLAYA's Avatar
MIAPLAYA
12nv can you give me the code number you are getting...
Old Jun 8, 2005 | 01:22 PM
1 2 NV's Avatar
1 2 NV
MIA, I left the little piece of paper from Advance Auto at home. I'll give my wife a call and see if she can find it and give you a buzz with the info, if the actual code gets printed on the piece of paper they give out. Cool?
Old Jun 8, 2005 | 01:26 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes it does...as soon as you can get that to me I will call Brad and get some more info for you....
Old Jun 8, 2005 | 02:41 PM
sa52's Avatar
sa52
1 2 NvV: You should make sure that when you installed the plugs back in you put the coil packs in order. I made this mistake when I install the 1-Step colder plugs when I finished my Vortech install last week. The code that came up on the OBII was a multiple cylinde misfire. On the wires connecting to the coil packs you will see a white paper with the cylinder # on it. They should be in the order starting from the passenger front side: 1 - 3 - 5 then to the driver side front: 2 - 4 - 6. Hope this helps.
Old Jun 8, 2005 | 03:41 PM
1 2 NV's Avatar
1 2 NV
I'll look into it but, if I remember correctly I did them 1 at a time. And I dont think I would be able to drive it like I have with the coils going to the wrong cylinder. Thanks
