are 350z & g35 vortech kit interchangeable???
Old Jun 13, 2005 | 07:49 AM
NismoGCoupe's Avatar
NismoGCoupe
Default are 350z & g35 vortech kit interchangeable???
Can anyone tell me if the 350z & g35 vortech kit are interchangeable.....I have a G35 coupe and Im in the process of buying a vortech kit that was on a 350z.....just want to double check before I paypal the money
Old Jun 13, 2005 | 08:21 AM
Phaneom's Avatar
Phaneom
Call Vortech 805.247.0226
Old Jun 13, 2005 | 07:49 PM
KPierson's Avatar
KPierson
I wouldn't recomend it. The Z Vortech kit has the air filter right on the inlet of the compressor. I believe the G Vortech kit has the filter inline between the compressor and the FMIC. There is a similar thread on g35driver.com about this and the Procharger right now.
Old Jun 13, 2005 | 08:05 PM
NismoGCoupe
I just noticed on avalon racing ad the voretch kit 350z/g35 have the same part #
Old Jun 13, 2005 | 08:06 PM
NismoGCoupe
Im sure I wouldnt have a problem installing into a g35 but I actually backed out of the sale for other reasons
Old Jun 14, 2005 | 04:33 AM
booger's Avatar
booger
Think that is backwards . The G35 kit has the filter on the blower
Old Jun 14, 2005 | 06:01 AM
Gary King's Avatar
Gary King
The part #'s from Vortech are different. I'm becoming more and more interested in this kit.
Old Jun 14, 2005 | 07:46 AM
sa52's Avatar
sa52
They are indeed the same kit. I just installed a 350Z kit on my G35 last week and it was no problem. PM me if you need any details.
Old Jun 14, 2005 | 08:10 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
They are the same kit...different part number..but same kit. The airfilters used to be different, but now they all come with the lower profiles. This means on the 350Z, you wont have to remove your blower just to change the airfilter!
HOWEVER, the program inside the SplitSecond box is different for the G35, as is the wiring diagram. So the car will probably need to be retuned, and you'll need to pick up the G35 wiring diagram to complete the installation.
If this is an older 350Z kit, it probably comes with the larger filter. You will definately want to pick up the newer lower profile filter. We sell all the Vortech replacement parts if you need anything.
Old Jun 14, 2005 | 11:26 AM
booger's Avatar
booger
Dont think you ever had to remove the blower . Just undo the filter and push it down into the fender well . The front inner fender comes off real easy to get to the filter and the oil squirter that needs to be cleaned every now and then . I think the wiring is the same . Same pin # , just diff. color wires . Just make sure you go by the pin # , not color
Old Jun 14, 2005 | 11:31 AM
NismoGCoupe
I dont think I would have to worry about wiring up the ss box...you already know my plans
Old Jun 14, 2005 | 11:40 AM
kopo's Avatar
kopo
Im including the smaller (g35 filter) with my 350z kit. I purchased it as a replacement from vortech.
Old Jun 14, 2005 | 11:45 AM
booger's Avatar
booger
__________________
You may want to look into running a 4inch diameter brake duct hose off the blower , down into the fender well with a bigger filter on it .Thats what I did . Able to run a much bigger air filter
Old Jun 14, 2005 | 01:57 PM
sa52's Avatar
sa52
In the installation directions for the kit it shows the different wiring diagrams for each the 350 and the G, they are the same just different color wires. As for the tune I would get it retuned no matter what you buy.
Old Jun 14, 2005 | 02:21 PM
Sharif@Forged
Forged Performance
That is correct. Sorry if I didnt make it as clear.
JjL
East Canada
Jun 12, 2019 03:04 AM
seagrasser
Oct 11, 2015 03:27 PM
issyz
Sep 12, 2015 04:18 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
