EGT Temps with Vortech
Old Jun 16, 2005 | 04:02 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by booger
We just got done tuning my car and EGT's never went above 1400 F this time . I reduced the timing and it didnt change the EGT's and made no diff in the power . I put the retard timing back in
Care to share your numbers?
Old Jun 16, 2005 | 04:26 PM
freezeg35's Avatar
freezeg35
My egt probe is pre cat and i get 1450 ish max when im crusing at 3500-4000 rpm. I also have a aem wideband so i know my a/f is good. Like stated placement is everything.
Old Jun 16, 2005 | 04:32 PM
zachcrosen's Avatar
zachcrosen
Isnt the ideal location as close as possible to where the header bolts up to the head? And then further away would logically be cooler. So if seeing around 1400 close to the cats, wouldnt you think it would be a little hotter closer to the head?
So what all does it mean if you are running really high EGTs?
Old Jun 16, 2005 | 04:44 PM
booger's Avatar
booger
400whp and 319 trq. [Mustang dyno ] Not what i expected . Got to think this AT5 is killing me . Boost leveled off at 13.5 at 6,300rpm > it did keep making power all the way to 6,900 rpm . Gained 50whp and 30 trq. over my last set up . We didnt try to get every last whp out of it . Kept it safe
Old Jun 17, 2005 | 06:05 AM
Sharif@Forged
Forged Performance
Booger 400whp on a Mustang dyno is AWESOME. From my experience, they read VERY low compared to a dyno jet. Add about 17% so that so get a rough estimate of dynojet numbers. The numbers sound good to me!
Old Jun 17, 2005 | 06:09 AM
Sharif@Forged
Forged Performance
By "pre-cat", do you mean on the upstream flange of the cat, or on the header, just before the cat?
Old Jun 17, 2005 | 06:49 AM
freezeg35's Avatar
freezeg35
yes, just before the cat.
Old Jun 17, 2005 | 01:15 PM
booger's Avatar
booger
Do you think its that high [ 1450 ] at cruise , because of the heat from the cat ? Im only seeing 1400 F. at WOT at redline .
Oh....THANKS Sharif....It does seem to pull twice as hard as my last [ pre rebuild ] set up .
Old Jun 18, 2005 | 08:23 AM
freezeg35's Avatar
freezeg35
Yeah im running all stock cats and exhaust right now. The cats are huge heatsinks so im not too worried about a higher crusing egt. I am installing stillen cat back exhaust in 2 weeks(got a great deal used) so i will see if that makes any difference. I also plan on crawford cats a little later on.
Chris350z03
Oct 8, 2023 07:19 PM
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
SharX59
Sep 27, 2015 09:23 AM
Calinismo350z
Sep 14, 2015 04:04 PM
