Vortech T-trim results
Old Jun 16, 2005 | 05:24 PM
booger's Avatar
booger
Default Vortech T-trim results
I got the car on the dyno for the first time since the rebuild , and the blower up grade . I got 400 whp and 319trq [ Mustang dyno ] . Not as much as I expected . Boost leveled off at 6,300rpm at 13.5 psi . I had the belt as tight as you would want to take it and it still slipped .On one run after tightening up the belt , I got 13.9psi , But after that one time it leveled off . We think if the belt wasnt slipping the boost would be around 14.5 to 15psi at redline .
All I can think is that this AT5 in this car is killing the whp and trq. . I would like to put this thing on a Dynojet just to be able to compare. With what others are getting . If the 10 to 12 % hold true . It would be at 440whp to 450whp . I know also , if the belt didnt slip up top , I would be 20 to 30 whp more .
Old Jun 16, 2005 | 06:29 PM
kevinapex's Avatar
kevinapex
nice boog! refresh my memory? What rwh# did you see before the T-trim, and was that on a Mustang dyno also?
Kevin.
Old Jun 16, 2005 | 06:32 PM
booger's Avatar
booger
Yes same Dyno....9psi on stock motor..350whp 289trq . Didnt dyno it with built motor and stock blower
Old Jun 16, 2005 | 07:09 PM
NismoGCoupe's Avatar
NismoGCoupe
what compression pistons did you go with? I would of kept them pretty close to the factory CR
Old Jun 16, 2005 | 07:11 PM
booger's Avatar
booger
9 to 1 pistons
Old Jun 16, 2005 | 07:26 PM
NismoGCoupe
Originally Posted by booger
9 to 1 pistons
why so low? also are you able to get more than 15lbs boost out of this blower or is that the max
Old Jun 17, 2005 | 04:26 AM
booger's Avatar
booger
I got the 2.87 pulley I could put on it . But the belt slips now at 13.5 psi at 6,300rpm . If I put on the 2.87..it would slip at 13.5psi and maybe 5,800rpm
Old Jun 17, 2005 | 05:14 AM
OldManZ350's Avatar
OldManZ350
Belt Slipping Problems.
See my post on belt fix/correction problems.
Booger-why don't you fix the belt?
it really is the way to go.
Old Jun 17, 2005 | 05:25 AM
NismoGCoupe
maybe you need to switch to and procharger or turbo setup..... you really wont have to worry about the belt slipping then
Old Jun 17, 2005 | 05:26 AM
booger's Avatar
booger
No matter which way you route the belt , or how tight you get it . Its going to start slipping when you reach a certain boost level . The belt cant grab enough to over come the preasure built up in the blower and pipe .
Old Jun 17, 2005 | 05:28 AM
booger's Avatar
booger
Give me the CASH and I'll switch . The ATI runs off a serp belt that drives the cog belt to
Old Jun 18, 2005 | 05:32 AM
kevinapex's Avatar
kevinapex
Us Vortech Guys gots to hold our ground! lol
Old Jun 18, 2005 | 07:25 AM
hndumafia's Avatar
hndumafia
if you add the 2.87 belt, even though the belt will still start slipping at 13.5 psi still, wouldn't you build boost faster?
Old Jun 18, 2005 | 12:02 PM
booger's Avatar
booger
[QUOTE=hndumafia]if you add the 2.87 belt, even though the belt will still start slipping at 13.5 psi still, wouldn't you build boost faster?[/QUOTE
I have thought of that too . We will see . I know I'll put this 400whp car up against any other claiming to have 400whp on a 3.33 ,3.12 , and 2.87 pulley with 8,9,10 , or 11psi
Old Jun 18, 2005 | 02:43 PM
hndumafia's Avatar
hndumafia
*sorry this is gonna be pretty off topic but i was wondering... *
another question about being able to build up boost quicker (and i'm sorry if this is stupid but i'm not that knowledgable about fi). say you have a s/c on a stock block and don't want to exceed say 9 psi. could you put on a pulley for higher psi and add a wastegate set to bleed off boost higher than 9, so you build boost faster but don't exceed a safe level of boost?
Old Jun 18, 2005 | 03:09 PM
booger's Avatar
booger
Some one has alresdy done it . Seems to work pretty good for him . I'll Have to remember who did it . I'm old....LOL ...bad memory
Old Jun 18, 2005 | 03:16 PM
booger's Avatar
booger
I remember now ..it is ...Gspot35 that has it on his sedan and the Vortech
Old Jun 18, 2005 | 03:38 PM
hndumafia's Avatar
hndumafia
is there is a reason that adding the wastegate is not more popular? i'm sorry to keep going more offtopic in your thread btw! it's just that i've been wondering about that for a while, and never saw anything about gspot35 doing that.
Old Jun 18, 2005 | 03:42 PM
booger's Avatar
booger
He put alot of work and $ into it . Dont think he is willing to give up much info on it . But do some research on it and Im sure you can figure it out
Old Jun 24, 2005 | 05:14 PM
booger's Avatar
booger
After talking to a couple of guys that tune on load base dyno's . It seems that every one adds 12 to 13 % [ some even more ] to thier numbers to read more like a dynojet dyno . Well after adding the 13% to mine . Im at 452whp and 355trq . If i had a 6MT we could add 20 to 30 more . I mentioned this on another thread today . That Dynojet dyno's are just big number producers...nothing more . They are not real world , real street HP. BUT , every one goes by Dynojet numbers to build up the EGO and try to be the top dog . Load base dyno's should be the norm , because what you make on a load base is what you'll have on the street . When some one hears that one certain dyno is putting out big numbers . Every one runs to get a dyno appointment with that shop . So the next shop adjusts thier dyno so it to reads higher and they get more buisness . Seem like it becomes a never ending cycle to boost EGO's and pocket books
