Vortech T-trim results
Old Jul 31, 2005 | 06:48 AM
  #41
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Originally Posted by mcduck
Whatever Actually my car made 420rwhp/340rwtq on a Dyno Dynamics dyno which is also a load based dyno. Besides, its hard to compare from one dyno to another even if they are the same type. Only true comparisons would be to have all these cars at the same dyno.
Anyway, nice numbers! Good luck trying to hit 450. I think to do so, tho, you'll have to go inside the tranny and build it up to handle the extra power.
Hey - my car made the same numbers on the same dyno...we are really close.
Old Jul 31, 2005 | 07:26 AM
  #42
Gman2004's Avatar
Gman2004
I believe CPrace's dyno has a 12% adjustment to make the numbers higher so they are comparable to a dyno jet. The dyno booger uses are real numbers and not fluffed.......not putting your numbers down just pointing that out. CPrace is going to tune my car in about two weeks.
Old Jul 31, 2005 | 01:44 PM
  #43
booger's Avatar
booger
another trick the tuner can do , [On a load base dyno ] is to NOT make the adjustment on the first run [ say 320whp ] ...do some timing and fuel tuning...add in the adjustment and do another run ...and to the amazment of the customer he now has ...390whp. When infact he only gained 20 or 30whp
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Calinismo350z
Sep 14, 2015 04:04 PM
