350Z Vortech Supercharger Dyno Graph W/ custom Tune
Old Jun 18, 2005 | 07:47 AM
CpraceZ's Avatar
CpraceZ
Default 350Z Vortech Supercharger Dyno Graph W/ custom Tune
We finished tuning this car a few weeks ago, the car is still on the stock vortech boost 8psi and made really good power honestly the most we have seen on our dyno with this set up.
Mods
Cat Back Exhaust
Vortech Supercharger 8 PSI
Custom Tune
www.cprace.com
Old Jun 18, 2005 | 09:29 AM
Gman2004's Avatar
Gman2004
You would be over 400whp on dynojet....very nice especially since you did it with the stock pulley. BTW, nice website. Welcome to my350z.
Old Jun 18, 2005 | 10:03 AM
CpraceZ's Avatar
CpraceZ
thanks man its great to be here, yeah we are slowly working on the site it is coming along though
Old Jun 18, 2005 | 10:07 AM
Gman2004's Avatar
Gman2004
Are you the guys that work on Sharif's car?
Old Jun 18, 2005 | 11:21 AM
CpraceZ's Avatar
CpraceZ
Yep we sure are
Old Jun 18, 2005 | 06:39 PM
GQ 350z's Avatar
GQ 350z
what exhaust yielded that power? Any different cats?
Old Jun 20, 2005 | 05:14 AM
CpraceZ's Avatar
CpraceZ
Stock Cats, I believe it was a Stillen exhaust
Old Jun 20, 2005 | 06:39 AM
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
did you upgrade your injectors? If so, which ones. Any reflashes?
Old Jun 21, 2005 | 05:41 AM
CpraceZ's Avatar
CpraceZ
No injector upgrade, and no reflash on the ECU, we did all the tuning with the split second software.
Old Jun 21, 2005 | 06:00 AM
GlenRoseFireFighter
that's good to know cuz I thought I was an anomaly. People were asking how I was getting in the same rage without inj or reflash...here's another example! Great job.
Old Jun 22, 2005 | 06:58 AM
CpraceZ's Avatar
CpraceZ
Yeah we have had a lot of luck with the split second software that comes in the vortech kits, it does not have as much room to work with as a greddy emanage would, or some other tuning options might have, but you can still make good power and tune safely with it.
Old Jun 22, 2005 | 07:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Very good numbers. Did you guys get a baseline? How much timing is being pulled? And last, could you post the a/f graph Id like to see it....
Old Jun 22, 2005 | 03:06 PM
black350's Avatar
black350
subscribing
Old Jun 22, 2005 | 03:49 PM
CpraceZ's Avatar
CpraceZ
Not quite sure on this one I would have to go back and look, most of the time we pull 5 to 7 degrees of timing, we never got a baseline on this car before we bolted the charger on, the lowest numbers we have seen at the wheel with our tuning is 360hp which was on a stock 350z with a charger, which was driven pretty hard before he decided to put the charger on. I will get a dyno graph with a/f in the morning.
Old Jun 22, 2005 | 04:06 PM
sponsorsthisway's Avatar
sponsorsthisway
With other mods such as cats, pleunum, headers, cams, and a reflash is there any way to hit the power a TT gives?
Old Jun 22, 2005 | 07:48 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is a great tuning job. And CP Racing has mastered the Split Second box and R4 Software.
It's possible to hit the same peak power as a stock TT kit, but you will never have the same trq or power curve. Since the TT's build boost very early in the power band (vs. the linear boost build of the SC), they produce more trq and power much sooner than a Vortech SC. So the cars will feel very different on the road. TT's also have more peak trq than the SC's.
Old Jun 22, 2005 | 08:14 PM
G352NV's Avatar
G352NV
Yep I had a chance to ride in a APS Z a couple days ago **** was crazy fast! I then had a chance to ride in a Vortech G with cams and smaller pulley. The APS car was making 440rwhp and the Vortech was making 430rwhp. They were both VERY fast but the ride in the Z is something I wont forget. I talked with the owner of the Z and he said even though his car has more HP the G had beat him a few times. I thought that was odd.
Old Jun 23, 2005 | 08:03 AM
CpraceZ's Avatar
CpraceZ
Even if a supercharged Z made the same power as a TT Z if you lined them up together the TT Z would pull away from the supercharged Z just because the power curve is so different. Nothing against the supercharging systems they are great and east to maintain and very easy to work with. A TT car is always going to have the edge on a supercharged car if they are making around the same HP, but yes it is very possible to get the superchargers around the same HP.
Old Jun 23, 2005 | 08:21 AM
mcduck's Avatar
mcduck
Does Dyno Dynamics typically read lower than a dynojet? CPRacing told me they have correction factors programmed in to adjust numbers on their dyno so they are within 3% of Dynojet readings since that is pretty much the industry standard measure (Note that I did not say it was the *best* measure)
Eric: Is this dyno from a Z running around Charlotte or one of your out of town customers?
Old Jun 23, 2005 | 09:48 AM
CpraceZ's Avatar
CpraceZ
We do have a correction factor setup on our dyno which gives us numbers that are comparable to those you would see on a Dynojet. We do this because most customers in our area are used to seeing Dynojet numbers rather than what our Dyno Dynamics would read without the correction factor.
Andy, this Z is from out of town although not too far out of town if I remember correctly. Think about an hour or two out of Charlotte. I'll ask Eric exactly where the guy was from, cause I can't remember.
