Greddy Catch Can Install-*PICS*
Old Aug 15, 2005 | 04:47 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
any time i remove my intake piping, there is definately an accumulation of oil at the rubber hose fittings (where they contact the piping)
any tips on the steel wool...do you just pack it inside the catch can?
what prevents fragments from getting through?
also, does anybody know how the inside of the greddy universal catch can is designed? is it just hollow? are there baffles/channels inside that prevent the oil from just blowing straight through?
Old Aug 15, 2005 | 06:00 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by STFU Tuning
In the past, we have found ways to baffle the inside of the catch cans so that they actually trap all the blow by. This was helpfull on Subarus that tend to like the vacuum assist with evacuating the crank case pressure.
Todd, this is exactly what I was talking about when i said to stuff the catch tank with stainless steel wool, the coarse kind that you use to scrub pots and pans. There is a really fine one (strands are about the same size as a humna hair if not smaller), than there is another kind.
Here is the fine one that I would NOT use, although it makes a PERFECT baffle.
It's probably ok to use the above if you can make some sort of a VERY secure netting to enlcose it in, but I'd be having nightmares of some of those strands dislodging and ending up in your combustion chanmber. Not worth it.
it's from this pages that you may find helpful: http://www.c-speedracing.com/howto/c...s/dsc00258.jpg
This was also a good thread: http://64.233.179.104/search?q=cache...h+can%22&hl=en
The coarse one looks more like a bunched up "pile" of ribbon tape couple of millimeters in diameter.
HTH
Old Aug 15, 2005 | 07:36 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Gurgen...please explain again, why i should only trap oil from the passenger side vs both...i have been getting conflicting info...please elaborate
THX
Old Aug 15, 2005 | 10:23 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
THX
You can trap it from both if you have two oil catch cans, connected separately. But I think what you are getting at is what I mentioned when we met. The d-side valve cover vent, the one that plugs into the nipple on the d-side turbo inlet pipe, is already internally baffled, according to the diagram in the service manual. hence, the larger source of the oil would be the unbaffled, valved p-side valve cover.
Old Aug 15, 2005 | 10:48 PM
STFU Tuning's Avatar
STFU Tuning
Can anyone confirm that the vacuum is really necessary on the Z?
Old Aug 16, 2005 | 03:34 AM
neffster's Avatar
neffster
Subscribing. My catch can goes in within the next 10 days...
Old Aug 17, 2005 | 05:15 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default Yet another update***
so, after talking it over with Gurgen and Sharif, I decided to hook the catch can up like it was before...even though this provides very little vacuum...
i stuffed the catch can full of coarse steel wool (really like stainless steel ribbon from albertsons )
i fabricated an in-line filter to catch any steel particles that may try to get by...
here's the pics:
stuffing the steel into the small a$$ holes:
here's the little thimble like filter i used..it is a A/C filter from NAPA..part number on card:
fits inside the 1/2 inch line perfectly...just snug
had to:
this is where i got really creative..i wanted to make this in-line filter easy to take off and inspect/clean...so, i took an old cheap socket and drilled it out:
then used that to hold the thimble looking filter in place...from not getting pushing through the hose:
final product:
look at the can on this catch:
i'll be taking orders on my how-to's shortly
Old Aug 17, 2005 | 06:43 PM
failsafe306's Avatar
failsafe306
I'd like a 'how-to' on how to score a chick like that!
Old Aug 17, 2005 | 07:12 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
first spend thousands of dollars making your 350z insanely fast..then comes girl
hahahah
Old Aug 18, 2005 | 09:04 AM
neffster's Avatar
neffster
Aren't you worried about oil build up on the 'thimble'? If there was any blow by, wouldn't dirt and oil just collect here and clog your passage way completely? Is there enough of a vacuum to keep this from happening?
Old Aug 18, 2005 | 11:55 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
i am hoping that hardly ANY debris gets by my stuffed catch can...but my concern, more of a paranoa..is if a metal fragment gets through and gets sucked into the turbo...im gonna check the thimble evry couple of days..that's why i made the quick disconnect dealy, so i could monitir what was going on ...i should just make that line clear, i think i'll do that soon actually
so, anyway, i'll check it on a regular basis and get a better idea of how much and how quickly anything, if anything, gets stuck in the thimble filter
Old Aug 18, 2005 | 01:40 PM
failsafe306
hahahah
Spend thousands on fast car: check
When do I get my girl?
Old Aug 18, 2005 | 01:58 PM
g356gear's Avatar
g356gear
Do you look like Ron Burgandy???
Old Aug 18, 2005 | 02:12 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Nice pics todd,
I have about 4 more of the catch cans arriving tomorrow, if anyone needs one.
Old Aug 18, 2005 | 03:51 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
hahaha, lmao
Old Aug 18, 2005 | 09:52 PM
failsafe306
Yea, well I have more chest hair and my mustache is thicker, so I should be rolling in the wool. I don't get it
Old Aug 19, 2005 | 02:46 PM
failsafe306
Wow^^^^^^ Drunk post!
Old Aug 20, 2005 | 09:28 AM
  #38
chemicalviper's Avatar
chemicalviper
Just out of curiousity, isnt the cusco one have a removable top ? Also, its not like the blow-by is flowing 250+cfm enough to destroy STEEL debri away from the wool.
Old Aug 20, 2005 | 04:21 PM
  #39
350zDCalb's Avatar
350zDCalb
builtZmotors
not worried about the pressure (or lack there of) in breaking steel fragments off and allowing them to find their way into the turbo...i am acting cautiously to prevent any EXISTING fragments in the can to be pushed through...i had to cut the steel wool to pack it in the can, i was as careful as i could be to not stuff any free floating steel debris in the can, but better safe than sorry
and i've heard a few have a removable top...but the greddy one is so pretty
Old Mar 30, 2006 | 07:02 AM
  #40
gringott's Avatar
gringott
Just wondering - does anyone who has the ARC one know what hoses are connected to it? Both sides or just one, and does it reconnect to the intake? Anyone know of a problem if I just use a breather catch can and vent to atmosphere on both the passenger and driver side? Other than oil odor? After all, I don't drive a hybrid!
