HELP! somethings wrong with my car!
Old Jun 29, 2005 | 01:01 PM
t32gzz's Avatar
t32gzz
Not sure about the guages, but definitely sounds like the 2K issue on the rpm is a limp mode issue. If you can clear the SES light via scanner, it may fix your problem. I think you are going to have to go to the dealer.
Try unplugging the MAF sensor harness and plugging it back in. It always worked for me when I went into limp mode.
Old Jun 29, 2005 | 05:13 PM
booger's Avatar
booger
Cat...did you say what gauges weren't working ? Sure sounds like the dredded limp mode . But never seen it screw with the dash gauges
zzzya's Avatar
zzzya
I ran into a similar problem when I had a ground wire that shorted. I have an automatic and when this occurred the car would only drive in 4th gear and would not go over a certain rpm. I also had a SES light and the code basically said it was a problem with the wiring. I took it to the dealer and they found the faulty ground within a couple of hours and had it fixed. Hopefully it all works out for you as well.
Old Jun 30, 2005 | 04:18 AM
jpc350z's Avatar
jpc350z
Gauges? Could be a bad crank angle sensor!
Old Jun 30, 2005 | 05:16 AM
Machupo's Avatar
Machupo
one way to rule out the split second box would be to disconnect the SC, reset the ECU, and see if it will run N/A mode...
if it still acts up, i'm leaning towards the CAS sensor as well, though, wouldn't you hear detonation then?
Old Jun 30, 2005 | 05:37 AM
jpc350z's Avatar
jpc350z
Believe it then uses the cam sensor if the crank fails..
Old Jun 30, 2005 | 05:42 AM
booger's Avatar
booger
I think if she has the wire harness and the SS box is wired into it , she just can unplug the harness and hook it back up like stock . Dont think she even would have to take off the SC cog belt to see it works
Old Jun 30, 2005 | 07:10 AM
Machupo's Avatar
Machupo
true, since the vortech is supposed to work OOTB / with stock tune, right?
Old Jun 30, 2005 | 07:27 AM
booger's Avatar
booger
OOTB ? dont know that one . But , yes she would be fine as long as she dont boost it . Maybe rich , till it relearns though .
Old Jun 30, 2005 | 08:50 AM
DBZCat's Avatar
DBZCat
car is at the shop now, just waiting to see what they say, I passed along the comments from this thread for them to try out, so we will see.
awaiting impatiently on the call. the more and more I think about it, the more I think it is limp mode and some shortage or wire problem.
Old Jun 30, 2005 | 11:11 AM
booger's Avatar
booger
Cat...you do have the wire harness that you have the SS box wired into right ? If they think its some wire shortage , Have them take the harness out and plug the factory harness back into the ECU . Im sure they have tried to reset the ECU already
Old Jun 30, 2005 | 11:21 AM
jpc350z's Avatar
jpc350z
If it's work under Warranty and they see a harness that did not come with the car from the factory I doubt they will even touch it.. Hopefully they will look up the ses code and determine the problem without having to hook up the stock cable..
Old Jun 30, 2005 | 11:59 AM
Zivman's Avatar
Zivman
Everyone that is running FI, NEEDS to invest in some sort of code reader.
The random SES lights that come on when you introduce FI need to be address immediately and not just by resetting the ECU. Most of the time they are something simple like a P2135 TPS, while other times they can be something major P0325 knocking that could potentially blow your motor.
For the 150-200 bucks that they cost, they are probably one of the most useful tools you will have and USE.
I run a Palm M125 with PocketLogger software that I have had for about 4 yrs now. It works great on the Z and I know immediately why a throw a CEL and can turn it off without even slowing the car down.
Link to all the OBDII codes for Nissan cars
Old Jun 30, 2005 | 12:39 PM
Machupo's Avatar
Machupo
sorry, "Out of the Box"
Old Jun 30, 2005 | 04:42 PM
pulpz2's Avatar
pulpz2
That's cool. If (when) I go FI , an car PC with full diagnostics is a no-brainer.
Old Jul 1, 2005 | 11:59 AM
NismoGCoupe's Avatar
NismoGCoupe
any word on what went wrong?
Old Jul 1, 2005 | 02:19 PM
DBZCat's Avatar
DBZCat
they said the codes the car was throwing had to deal with the throttle body?
Old Jul 1, 2005 | 02:22 PM
  #38
booger's Avatar
booger
Did they get it fixed ?
Old Jul 1, 2005 | 02:25 PM
  #39
DBZCat's Avatar
DBZCat
no not yet....they just know that the codes are dealing with the throttle body, they don't know why or how or anything... :/
Old Jul 9, 2005 | 01:43 PM
  #40
GZire's Avatar
GZire
Bump for update. Have they determined what's wrong with your car?
