eManage Ulimate--Almost here..and MUCH IMPROVED!
Old Jun 29, 2005 | 04:39 PM
zzzya's Avatar
zzzya
Originally Posted by Sharif@Forged
Well, like the current setup, there is no reason to get rid of the MAF, as it wont be used at all in the tuning process. But will remain so the ECU doesnt freak out, and will start, idle, and cruise the car like normal.
I will most likely host a GB on the product, but I would like everyone's opinion on something. I can actually get a bunch of these units much earlier than I thought...like next week. But I am reluctant to sell it to you guys without testing it out first.
Theoretically, it works just like the normal eManage, but about 5 times better in just about every way. I cant think of any reason that an eManage blue would work on the 350Z, and this Ultimate version wouldnt. I'd like to hear people's opinions on a GB on this, assuming we can get at least 5 people interested.
Retail on the unit is $680 and the ulitimate harness is $120. GB price will be waaaay lower than that....likely $560-0$580 shipped for the emanage, and about $100 for the harness, and of course, it will include technical support as always.
If you guys can wait a few weeks, I dont mine installing one and running some dyno tests on the units....road test..etc.
On a side note, the more I research this, the better I like it. Now, by tapping the injectors as we have in the past, you can actually enrich, AND REDUCE fuel via IPW changes. With the current eManage, you can only add fuel via IPW increases. I cant tell you how many times we have these rich dips in tuning, and its very challenging to get ride of them. With this system, its going to be a snap! This allows very precise mapping of fuel and timing, without messing with the MAF correction.
GB SERIOUS interest list:
1) sharif@forged
2) zzzya
3)
4)
5)
6)
7)
8)
9)
10)
11)
12)
13)
I am still NA but this would be much easier than the current fedex back and forth to TS for a reflash.
Old Jun 29, 2005 | 04:51 PM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Originally Posted by nis350ztt
With the V-Pro, cruise control and VDC or TCS does not work properly, with the ultimate eManage it will. That's enough for me to decide. Not to mention price vs. performance/features.
Since when?? They all work properly on the 8+ cars we have done with the Vpro
Old Jun 29, 2005 | 04:53 PM
Zexy's Avatar
Zexy
This sounds very interesting. How exactly could it benefit the NA guys?
Old Jun 29, 2005 | 05:02 PM
Jaki's Avatar
Jaki
This seems very promising, I just hope that its as good or even better than it sounds!
Since this would allow us to tune our cars more precisely and it would take better care of all the timing issues, would it then allow us to run our cars at a higher boost on stock internals or are the internals just too weak for so much power no matter how great the tune is?
Old Jun 29, 2005 | 05:04 PM
Gman2004's Avatar
Gman2004
Subsribing. I am interested in the GB but I won't put my name on the official list until the end of the week until I can sort out some things.
Old Jun 29, 2005 | 05:06 PM
THX723's Avatar
THX723
Sharif,
Will these fry the ignition coils (like the old eManage), unless diodes are used?
Old Jun 29, 2005 | 05:12 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
This is according to Charles@CJ-Motorsports.
Old Jun 29, 2005 | 05:35 PM
ImportPartsPro
He is wrong then....it works fine
Old Jun 29, 2005 | 06:02 PM
daddyz's Avatar
daddyz
Will this work for the Vortech?
Old Jun 29, 2005 | 06:14 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I'd like to see a GB delayed until we have some feedback on the unit. No place around here will have ANY experience with it yet. Would love to see you install it first and do a GB at the end of the summer or in the fall after we know how good it works. Just my .02
Old Jun 29, 2005 | 06:56 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
I'd like this GB to take place ASAP!!!
add me to the list!
1) sharif@forged
2) zzzya
3) 350zDCalb
4)
5)
6)
7)
8)
9)
10)
11)
12)
13)
Old Jun 29, 2005 | 07:31 PM
g356gear's Avatar
g356gear
1) sharif@forged
2) zzzya
3) 350zDCalb
4) g356gear
5)
6)
7)
8)
9)
10)
11)
12)
13)
Old Jun 29, 2005 | 07:35 PM
booger's Avatar
booger
+1
Old Jun 29, 2005 | 07:43 PM
Brandon@Forged
Any way we can work on pricing? I know of a place that sells it for $535 regular pricing and the harness is $85 (though it does not list the 350Z harness on GReddy's website).
(BTW, i'll be getting this if I get the car I told you about in PM)
Old Jun 29, 2005 | 07:44 PM
baileyrx's Avatar
baileyrx
will this work with my ati procharged g35??
I'm in Greensboro, how much would you charge to install & retune??
Old Jun 29, 2005 | 07:58 PM
AmyCroft's Avatar
AmyCroft
Default TCS - VDC - Cruise - Requires MAF
Yes Kyle...
Not sure about Charles' Z
But ZRayGo's Z - Were Running MAP with V-Con and the "TunerS Plural" pulled out the MAF.
Reason's:
The Car run's with no MAF.
The MAF seemed redundant to the "TunerS"
In practice the VDC and Cruise requires the Feedback loop information of the MAF to calculate the Vector list for VDC.
The CAN system spends extra time looking for lost Sensors.
Retries are re-transmitted on the Car Area Network.
Similar to a Flaky network card - that causes CRC errors while it retries.
If a complete ECU discovery cycle is incomplete, The ECU relies on the Previous vector Map's information.. And that's O.K. since:
The Fall Back information is adequate. After all the V-CON is in command.
And the full information is from a "Learning" cycle.
But Clear the ECU totally, by Battery off ( For a day )
Or exercising the ECU "Clear" method is used.
Then the ECU is in relearn.
First with the cold engine all is fine (except Idle)
When the Oil Temp reaches 160F - the loop that checks the O2 sensors
begins. Up until that time the ECU has "no long term O2" in the table.
The example is clearly demonstratable by removing the O2 sensors wires, when the Oil Temp is at 160 or 180 the Engine will surge up, surge Down as Fuel is adjusted. ( No feed back from O2's )
That's on a Stock ECU.. But since V-Con is in control of fuel, one never sees that occuring.
The Operation of the CAN is well documented. ( and hours of fun to read )
CJ & 350NOW can add the detail's on the Christmas Tree light's on the DASH.
Cheers Amy -
Last edited by AmyCroft; Jun 29, 2005 at 08:03 PM. Reason: Outside help - CJ & 350Now
Old Jun 29, 2005 | 08:24 PM
002-M-P's Avatar
002-M-P
Well I was planning on getting my car tuned within the next month, but I guess I should wait for this before I spend the money on tuning and increasing the boost, so had me to the list...
1) sharif@forged
2) zzzya
3) 350zDCalb
4) g356gear
5) 002-M-P
6)
7)
8)
9)
10)
11)
12)
13)
Old Jun 29, 2005 | 09:36 PM
  #38
johanna1's Avatar
johanna1
I am in. I was going to go with the F-CON, but don't know if I will be able to afford it. How much does it run anyways? Also, do you think it will be almost as good as the F-CON?
1) sharif@forged
2) zzzya
3) 350zDCalb
4) g356gear
5) 002-M-P
6) johanna1
7)
8)
9)
10)
11)
12)
13)
Attached Thumbnails eManage Ulimate--Almost here..and MUCH IMPROVED!-cnv0020.jpg
Old Jun 29, 2005 | 10:21 PM
  #39
phunk's Avatar
phunk
CJ Motorsports
I never said cruise and VDC dont work... I just said they dont work properly IMHO... I definatly noticed a major difference in the way they respond... however I spent much time with the FCON technition at HKS USA talking about it, and I think we figured out what the problem was, just never really cared to try it (i only had so much curiousity to it because I always want to know how everything works)... what is VDC gonna do for me other than make me loose a race when I forget to turn it off?!?!
Either wya, this E-Manage ultimate is gonna be a huge hit or miss... but everyone will buy one regardless so carry on!!
Old Jun 30, 2005 | 12:04 AM
  #40
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I am working on it now Brandon. Remember that the "other" person selling these adds 3% to the cost, and then shipping on top of that. The 3% is the paypal fee. I promise my price will be the lowest shipped price around....so no worries. I just need to finalize the quantities, so I gave a high side rough estimate.
I'd like to do this....keep the GB interest alive, and in the meantime, I will get a unit installed on our car for testing purposes. Those that are serious can place their orders on the website, but as always, nothing will be charged until we confirm the product works as promised, and product is ready to ship out. I just need orders in hand, as a commitment from everyone.
I'll add this to the website shortly....stay tuned.
