HKS Rotrex install on an auto
Old Jul 18, 2005 | 12:31 PM
forcedinductee's Avatar
forcedinductee
Default HKS Rotrex install on an auto
hi i am just starting the install of the HKS Rotrex s/c on a 350z convertable auto trans bone stock with 6032 miles on it, well the only mod that the car has is gramlights wheels and T1-S tires. i am going to port the compressor housing and change a few other things i will keep you all informed as to how this goes. i also have a Dynojet chassis dyno in my shop and i will fill you all in with the numbers that this kit produces.
Old Jul 18, 2005 | 01:30 PM
roncfpz's Avatar
roncfpz
Definitely looking forward to your update. I'm in the process of chosing between HKS and Vortech. Good luck!
Old Jul 18, 2005 | 01:39 PM
forcedinductee
i will keep you informed!
Old Jul 19, 2005 | 11:46 AM
forcedinductee
this is the section that i will be removing. i showed only a portion of it in red so you could see the comparison.
Old Jul 19, 2005 | 12:28 PM
forcedinductee
stock opening is 48.84mm and the new opening will be 59.91mm
Old Jul 25, 2005 | 11:57 AM
forcedinductee
dynoed the car friday and it made 272.39 whp and 282.63 torque
93.12 degrees f 41% humidity
also car still has complete stock exhaust.
Old Jul 25, 2005 | 02:17 PM
sukhi's Avatar
sukhi
Did you do a baseline before you installed the supercharger? Was the result what you were expecting? How does it feel?
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
